주요 콘텐츠로 건너뛰기
해당 분해도는 작업 중 입니다 – 최신 변경 사항을 보려면 주기적으로 다시 로드 하십시오!
필요한 것
  1. Audiovox CD-Radio Teardown, Audiovox CD-Radio Teardown: 1 단계, 이미지 1/3 Audiovox CD-Radio Teardown, Audiovox CD-Radio Teardown: 1 단계, 이미지 2/3 Audiovox CD-Radio Teardown, Audiovox CD-Radio Teardown: 1 단계, 이미지 3/3
    • Here it is, ready to be torn'd!
  2. Audiovox CD-Radio Teardown: 2 단계, 이미지 1/3 Audiovox CD-Radio Teardown: 2 단계, 이미지 2/3 Audiovox CD-Radio Teardown: 2 단계, 이미지 3/3
    • Pop off the battery cover and remove the 6 C batteries. Keep them though, they might still be good.
    • Unscrew the 4 highly visible screws with the medium size screwdriver.
    • You'll need a longer bit or a different screwdriver for the other 3 holes. I attempted to unscrew it with my bit based driver, but was unsuccessful.
  3. Audiovox CD-Radio Teardown: 3 단계, 이미지 1/3 Audiovox CD-Radio Teardown: 3 단계, 이미지 2/3 Audiovox CD-Radio Teardown: 3 단계, 이미지 3/3
    • Work your way around the edge shown here with your fingers until a crack appears. Then it should be easy to lift the bottom off.
    • Be careful, The bottom is attached by a few wires. I nearly ripped these apart as I removed the bottom of the case.
  4. Audiovox CD-Radio Teardown: 4 단계, 이미지 1/3 Audiovox CD-Radio Teardown: 4 단계, 이미지 2/3 Audiovox CD-Radio Teardown: 4 단계, 이미지 3/3
    • Now, hunt down all the little screws on the motherboard and remove them. There are 4 or 5, so if it doesn't want to move, it's probably being held by a screw or two.
    • Now that all the screws, are gone, slowly lift and remove the motherboard. I say slowly because there are still a few cables attatched to the underside.
    • Disconnect all cables that aren't soldered on.
  5. Audiovox CD-Radio Teardown: 5 단계, 이미지 1/3 Audiovox CD-Radio Teardown: 5 단계, 이미지 2/3 Audiovox CD-Radio Teardown: 5 단계, 이미지 3/3
    • Now that those cables are removed, lift the motherboard up and out... or not.
    • The motherboard is attached to the LCD board via one of those pesky ribbon cables that's soldered on both ends and always seems to be covered in some sticky substance.
    • Lift the motherboard up so you have a good view of the LCD board.
platnicat
회원 가입일: 10/11/09
44 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 1,339
