주요 콘텐츠로 건너뛰기
해당 분해도는 작업 중 입니다 – 최신 변경 사항을 보려면 주기적으로 다시 로드 하십시오!
필요한 것
  1. Black and Decker AS150 Steam Advantage Iron Teardown, Examine the Iron: 1 단계, 이미지 1/3 Black and Decker AS150 Steam Advantage Iron Teardown, Examine the Iron: 1 단계, 이미지 2/3 Black and Decker AS150 Steam Advantage Iron Teardown, Examine the Iron: 1 단계, 이미지 3/3
    • Note that the base of the iron is detached from the upper portion where the dials and handle are location.
  2. Black and Decker AS150 Steam Advantage Iron Teardown, Remove all visible screws: 2 단계, 이미지 1/3 Black and Decker AS150 Steam Advantage Iron Teardown, Remove all visible screws: 2 단계, 이미지 2/3 Black and Decker AS150 Steam Advantage Iron Teardown, Remove all visible screws: 2 단계, 이미지 3/3
    • First remove all the large screws that detach the silver hot plate from the plastic piece attached to it. Lift the white plastic piece to reveal the inner workings of the iron (see last photo attached)
  3. Black and Decker AS150 Steam Advantage Iron Teardown, Clear dust off: 3 단계, 이미지 1/1
    • This iron was particularly dusty, clear the dust away with a toothbrush or other small brush. The result is shown in the photo; a clean, dust free iron.
  4. Black and Decker AS150 Steam Advantage Iron Teardown, Further Remove Screws: 4 단계, 이미지 1/2 Black and Decker AS150 Steam Advantage Iron Teardown, Further Remove Screws: 4 단계, 이미지 2/2
    • Remove the smaller screws located near the square(back) end of the iron releasing cords and wires. Also remove little orange rubber gaskets, and white plastic spacers, taking note where everything was. At this point, your iron should be completely disassembled, and should look like the last photo attached.
  5. Black and Decker AS150 Steam Advantage Iron Teardown, Re-assemble: 5 단계, 이미지 1/3 Black and Decker AS150 Steam Advantage Iron Teardown, Re-assemble: 5 단계, 이미지 2/3 Black and Decker AS150 Steam Advantage Iron Teardown, Re-assemble: 5 단계, 이미지 3/3
    • Beginning with the spacers and gaskets, replace these parts where they belong. Then re-install the small internal screws, taking care to reattach the wires and cords with them. Close the white plastic plate onto the metal hot plate and re-attach the larger main screws. Place black dial receptacle into orange slot (as pictured).
Jayda
회원 가입일: 11/13/14
231 평판
안내서 1개 작성함
Texas A&M, Team 1-1, Garza Fall 2014 Texas A&M, Team 1-1, Garza Fall 2014 회원
TAMCC-GARZA-F14S1G1
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 10
30일 전: 25
전체 시간: 5,022
