주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. BlackBerry 8700c 수리는 저희 서비스 설명서를 사용하십시오.
  1. BlackBerry 8700c Teardown, BlackBerry 8700c Teardown: 1 단계, 이미지 1/1
    • In this first step you will remove the battery cover by pushing down on the button on the cover and sliding towards the bottom of the phone.
    • To do this unscrew all four T6 screws
    • Once this is done gently remove the back cover of the phone by pulling first from the bottom towards you, then from the top upwards.
  2. BlackBerry 8700c Teardown: 2 단계, 이미지 1/1
    • To remove the battery, place your fingernail in the slot at the top right of the battery and pull up.
  3. BlackBerry 8700c Teardown: 3 단계, 이미지 1/3 BlackBerry 8700c Teardown: 3 단계, 이미지 2/3 BlackBerry 8700c Teardown: 3 단계, 이미지 3/3
    • Next, remove the back portion of the phone by removing four T6 Screws.
    • Once the screws have been removed, firmly grab the back cover and pull back from the front cover.
  4. BlackBerry 8700c Teardown: 4 단계, 이미지 1/2 BlackBerry 8700c Teardown: 4 단계, 이미지 2/2
    • To remove the middle portion of the phone you will again remove four T6 screws.
    • Follow the removal of the screws, you can now pull the front face plate away from the middle portion.
  5. BlackBerry 8700c Teardown: 5 단계, 이미지 1/2 BlackBerry 8700c Teardown: 5 단계, 이미지 2/2
    • Follow the removal of the screws, you can now pull the middle portion away from the main logic board.
    • Next, hold the logic board and remove the front face plate of the phone
  6. BlackBerry 8700c Teardown: 6 단계, 이미지 1/2 BlackBerry 8700c Teardown: 6 단계, 이미지 2/2
    • When the front face plate has been pulled away, be sure to grab the keypad as it may fall out.
  7. BlackBerry 8700c Teardown: 7 단계, 이미지 1/2 BlackBerry 8700c Teardown: 7 단계, 이미지 2/2
    • Next, use a metal spudger to unhook the earpiece from the inside of the front panel.
  8. BlackBerry 8700c Teardown: 8 단계, 이미지 1/3 BlackBerry 8700c Teardown: 8 단계, 이미지 2/3 BlackBerry 8700c Teardown: 8 단계, 이미지 3/3
    • Using a metal spudger, push back on the four clips holding the LCD screen to the logic board.
    • Next gradually pull the screen away from the board so that none of the clips are engaged.
    • Last, use a metal spudger to push back on the clip locking in the ribbon cable for the screen.
  9. BlackBerry 8700c Teardown: 9 단계, 이미지 1/1
    • The screen is now fully detached, and the phone is completely disassembled.
k3nt
회원 가입일: 10/28/09
42 평판
안내서 4개 작성하였습니다
Cal Poly, Team 18-4, Maness Fall 2009 Cal Poly, Team 18-4, Maness Fall 2009 회원
CPSU-MANESS-F09S18G4
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 8
전체 시간: 6,547
