주요 콘텐츠로 건너뛰기
해당 분해도에 사용된 도구
소개
This thing landed in our laps. We tried it, tested it, and then ripped it apart! All information can be found at www.phonewreck.com.
해당 분해도는 수리 안내서가 아닙니다. BlackBerry Presenter 수리는 저희 서비스 설명서를 사용하십시오.
  1. The BlackBerry Presenter ~$200 Solid Design
    • The BlackBerry Presenter
    • ~$200
    • Solid Design
    • A clever design trick,the Power Button is the Blackberry Logo
  2. Moving around the back, we see all of the ports
    • Moving around the back, we see all of the ports
    • VGA Port
    • S Video Port
    • Micro Usb
    • NTSC/PAl Switch
  3. Peel back the Rubber pad on the bottom of the device.
    • Peel back the Rubber pad on the bottom of the device.
  4. Grab your T7 and poke it through the adhesive pad. Remove the four screws. The top portion of the device should lift free, pretty easily.
    • Grab your T7 and poke it through the adhesive pad.
    • Remove the four screws. The top portion of the device should lift free, pretty easily.
  5. There's the PCB! Now to get under it..
    • There's the PCB! Now to get under it..
  6. Grab a small wrench  or a pair of pliers and remove the screws holding in the VGA port.
    • Grab a small wrench or a pair of pliers and remove the screws holding in the VGA port.
  7. Focus Enchancments : FS455LF   0731 kox4h00  is a TV encoder designed for applications which require Component Video, VGA, or RGB output capabilities.It can accept digital video or computer graphics in many different resolutions and rates, and convert them to high quality analog video. TI TMS320 DM350ZWX
    • Focus Enchancments : FS455LF 0731 kox4h00 is a TV encoder designed for applications which require Component Video, VGA, or RGB output capabilities.It can accept digital video or computer graphics in many different resolutions and rates, and convert them to high quality analog video.
    • TI TMS320 DM350ZWX
    • ST microelectronics
drwreck
회원 가입일: 2009년 11월 11일
1,432 평판
안내서 11개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 5,726
