소개
Here I show you how you can teardown your Bosch vacuum cleaner. The exact Model: BSGL5ZOO2/10
필요한 것
Remove residue bag G8.
Remove HEPA high efficiency hygiene filter 579496 VZ154HFB
Remove motor protection filter 578863 VZ01MSF
Use the spudger to lever the start button upwards from the front and remove it.
Lift the top of the housing from the handle side
Remove the top of the housing towards the rear.
Remove motor cover towards the back.
Carefully remove the circuit board from the guides of the cable drum.
The motor is now accessible.
Repeat the steps in reverse order to reassemble your device.
다른 2명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
