분해도
Spudger
$3.99
Phillips #000 Screwdriver
$5.49
We are going to teach you how to take apart and put back together a Cannon Powershot N.
해당 분해도는 수리 안내서가 아닙니다. Canon PowerShot N 수리는 저희 서비스 설명서를 사용하십시오.
Locate battery housing cover.
Place finger on the textured portion of battery housing cover and slide cover in the direction indicated.
Find beige tab and push it away from the battery.
Remove battery from battery slot with fingers.
Using a PH000 size screwdriver, unscrew four screws beneath screen.
Remove 2 screws on the bottom of the camera.
Remove 2 screws from the side of the camera with the on and off buttons.
Remove the back plate.
Locate 2 screws on “on/off” side of the camera and unscrew them.
Locate 2 screws on the other side of the camera and remove them.
Remove one screw from the bottom of the camera.
Remove front plate from motherboard so that one ribbon cable is exposed.
Locate the second ribbon cable.
Using plastic spudger, push tab to release the ribbon cable.
Locate screw under released ribbon cable and remove it.
With the camera lens facing you, remove 4 screws around the lens.
Flip over and remove 1 screw from side with playback/phone options .
Unscrew 2 screws from top, bottom, and both sides of screen.
Pull off white cap which edges the screen.
Remove white metal plate behind screen (tip: try not to bend).
Push out LCD screen.
다른 기여자 4명과 함께
회원 가입일: 2016년 03월 04일
313 평판
안내서 1개 작성함
배지: 2
UMASSD-BHUSAL-S16S6G5
3 회원들
안내서 1개 작성하였습니다
해당 안내서를 사이트/포럼에 작은 위젯으로 포함하려면 크기를 선택하고 아래 코드를 복사하십시오.
24 시간 전: 0
7일 전: 2
30일 전: 8
전체 시간: 978
