주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Car and Drivers Auto HandHeld Vacuum Bagless 수리는 저희 서비스 설명서를 사용하십시오.
  1. Car and Drivers Auto HandHeld Vacuum Bagless Teardown, Car and Drivers Auto HandHeld Vacuum Bagless Teardown: 1 단계, 이미지 1/3 Car and Drivers Auto HandHeld Vacuum Bagless Teardown, Car and Drivers Auto HandHeld Vacuum Bagless Teardown: 1 단계, 이미지 2/3 Car and Drivers Auto HandHeld Vacuum Bagless Teardown, Car and Drivers Auto HandHeld Vacuum Bagless Teardown: 1 단계, 이미지 3/3
    • Locate the four screws locate outer gray shelll
    • ''I REMOVED THE SCREWS WITH PH #OO SCREWDRIVER FROM (IFIXIT)
    • New PLace four screws to the side
  2. Car and Drivers Auto HandHeld Vacuum Bagless Teardown: 2 단계, 이미지 1/1
    • Here are the four screws from vacuum
  3. Car and Drivers Auto HandHeld Vacuum Bagless Teardown: 3 단계, 이미지 1/3 Car and Drivers Auto HandHeld Vacuum Bagless Teardown: 3 단계, 이미지 2/3 Car and Drivers Auto HandHeld Vacuum Bagless Teardown: 3 단계, 이미지 3/3
    • Remove the top grey shell of the vacuum
    • Place a red tab to the side
    • Let start looking at the 9volt motor with wire and on/off switch.
    • I remove the outer shell . I remove the motor and wires and on/off switch.
  4. Car and Drivers Auto HandHeld Vacuum Bagless Teardown: 4 단계, 이미지 1/1
    • This it complete teardown on Car and Driver HandHeld Vacuum bagless!
kempc8
회원 가입일: 11/22/13
899 평판
안내서 7개 작성하였습니다
K and K Fixit K and K Fixit 회원
Business
1 회원
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 13
전체 시간: 1,054
