주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Casio Watch 수리는 저희 서비스 설명서를 사용하십시오.
  1. Casio Digital Watch Teardown, Casio Digital Watch: 1 단계, 이미지 1/1
    • This is a teardown of a Casio Digital Watch down to the internal circuitry.
    • You will need a small Phillips screwdriver for this teardown.
  2. Casio Digital Watch Teardown, Remove the Case: 2 단계, 이미지 1/1
    • Carefully remove the four screws on the backside of the watch.
    • You will need an extremely small screwdriver. A screwdriver to repair glasses would work.
  3. Casio Digital Watch Teardown, Gently Push out the Screen: 3 단계, 이미지 1/2 Casio Digital Watch Teardown, Gently Push out the Screen: 3 단계, 이미지 2/2
    • Press your fingers on the screen and remove the watch from its case.
    • Be sure to save the three buttons that control the watch
  4. Casio Digital Watch Teardown, Remove the Battery Holder: 4 단계, 이미지 1/3 Casio Digital Watch Teardown, Remove the Battery Holder: 4 단계, 이미지 2/3 Casio Digital Watch Teardown, Remove the Battery Holder: 4 단계, 이미지 3/3
    • Remove the Battery Holder surrounding the circuitry of the watch by carefully pulling off each of the four clips.
  5. Casio Digital Watch Teardown, Remove the Battery: 5 단계, 이미지 1/1
    • Remove the battery by pulling from the sides to unstick the adhesive.
  6. Casio Digital Watch Teardown, Detach the LCD: 6 단계, 이미지 1/2 Casio Digital Watch Teardown, Detach the LCD: 6 단계, 이미지 2/2
    • Remove the four plastic pins connecting the LCD and remove the LCD holder
  7. Casio Digital Watch Teardown, Teardown Complete: 7 단계, 이미지 1/1
    • This reveals the internal circuitry of the watch, and the teardown is complete.
Cooper
회원 가입일: 02/24/15
457 평판
안내서 2개 작성하였습니다
Cal Poly, Team 24-6, Green Winter 2015 Cal Poly, Team 24-6, Green Winter 2015 회원
CPSU-GREEN-W15S24G6
4 회원들
안내서 15개 작성하였습니다
댓글 2개
This is my Casio 5 alarm tear down. Can u tell me if this has anything on it that u guys didn't do. Please email me at dolphinzpride@gmail.com...
https://linksharing.samsungcloud.com/wQ5...
Skylar Miller - 답글
I have casio illuminator dual time watch, it was damaged outerward accidentally , but internal systems r safe. But now its digits r not displaying properly, sometimes digit parts r missing n sometimes fully 888888 r shown
Sarabjeet Singh - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 34
30일 전: 144
전체 시간: 12,698
