주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Caterpillar B15 수리는 저희 서비스 설명서를 사용하십시오.
  1. Caterpillar B15 Teardown, Caterpillar B15 Teardown: 1 단계, 이미지 1/1
    • Place the phone screen-side down and place thumb on the yellow and black switch. Slide the switch to the right to unlock the back covering for removal.
  2. Caterpillar B15 Teardown: 2 단계, 이미지 1/2 Caterpillar B15 Teardown: 2 단계, 이미지 2/2
    • Remove the back covering by gently lifting upwards from the bottom of the back covering. The back will snap off and the battery is exposed.
  3. Caterpillar B15 Teardown: 3 단계, 이미지 1/2 Caterpillar B15 Teardown: 3 단계, 이미지 2/2
    • Place index finger at the top edge of the battery and gently lift upwards. The battery will slide cleanly out of the phone.
  4. Caterpillar B15 Teardown: 4 단계, 이미지 1/2 Caterpillar B15 Teardown: 4 단계, 이미지 2/2
    • With the back cover removed, locate and remove the Phillips screw pictured top-center, and the two torx screws above and to either side of the Phillips screw. A T-5 bit is required for removal of the torx screws.
    • WARNING: Proceeding beyond this point will void the warranty for this device.
  5. Caterpillar B15 Teardown: 5 단계, 이미지 1/1
    • Next, remove the two torx (star-shaped) screws below the battery. These screws help to secure the outer shell of the phone around the motherboard. A T-5 bit is required for removal.
  6. Caterpillar B15 Teardown: 6 단계, 이미지 1/1
    • There are three remaining screws on each long side of the phone. A small hex bit is required for removal.
  7. Caterpillar B15 Teardown: 7 단계, 이미지 1/1
    • There is one more Phillips screw remaining. It is located beneath the headphone cover.
  8. Caterpillar B15 Teardown: 8 단계, 이미지 1/1
    • With all screws removed, the back and side pieces should come off the front of the phone, exposing the motherboard and various components as shown.
  9. Caterpillar B15 Teardown: 9 단계, 이미지 1/1
    • With all screws removed, move around the motherboard, carefully prying it from the remaining shell.
  10. Caterpillar B15 Teardown: 10 단계, 이미지 1/1
    • Finally, disconnect the chip seen in the upper right, and the board should pull away from the rest of the phone.
  11. Caterpillar B15 Teardown: 11 단계, 이미지 1/1
    • Congratulations. You have successfully disassembled the Caterpillar B15.
Geoffrey Mosdell
회원 가입일: 10/06/14
1,119 평판
안내서 5개 작성하였습니다
USF Tampa, Team 4-7, Brown Fall 2014 USF Tampa, Team 4-7, Brown Fall 2014 회원
USFT-BROWN-F14S4G7
4 회원들
안내서 10개 작성하였습니다
댓글 2개
Hi,
where can i buy T5 Torx screws for CAT B15 ?
Regards,
Laurent NOEL
Laurent NOEL - 답글
Any idea where I can get the rubber piece that covers the USB port? The one repair shop in the US wants about $200 for that repair.
John Nagle - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 14
30일 전: 27
전체 시간: 11,433
