주요 콘텐츠로 건너뛰기
해당 분해도는 수리 안내서가 아닙니다. Christmas tree 수리는 저희 서비스 설명서를 사용하십시오.
  1. Christmas Tree Teardown, Christmas Tree Teardown: 1 단계, 이미지 1/1
    • The teardown shows a christmas tree Nano, but should you have a bigger - Classic one, you may follow these steps - upscaling everything.
  2. Christmas Tree Teardown: 2 단계, 이미지 1/2 Christmas Tree Teardown: 2 단계, 이미지 2/2
    • First order of business: presents!
    • Use caution and joy when opening your presents.
  3. Christmas Tree Teardown: 3 단계, 이미지 1/2 Christmas Tree Teardown: 3 단계, 이미지 2/2
    • Disconnect the power plug
    • Remove the power socket, should there be one on your tree.
  4. Christmas Tree Teardown: 4 단계, 이미지 1/1
    • To remove the baubles, lift them gently and untangle the string from the branch.
  5. Christmas Tree Teardown: 5 단계, 이미지 1/3 Christmas Tree Teardown: 5 단계, 이미지 2/3 Christmas Tree Teardown: 5 단계, 이미지 3/3
    • If you find a capacitor on your christmas tree, straighten its leads to detach it.
    • All discrete electronic elements should be removed in this manner.
  6. Christmas Tree Teardown: 6 단계, 이미지 1/1
    • Protective hand-wear may come in handy.
  7. Christmas Tree Teardown: 7 단계, 이미지 1/1
    • Remain gentle, even when an element is very difficult to untangle.
  8. Christmas Tree Teardown: 8 단계, 이미지 1/2 Christmas Tree Teardown: 8 단계, 이미지 2/2
    • To remove the top ornament, lift it upwards.
  9. Christmas Tree Teardown: 9 단계, 이미지 1/1
    • Finally, remove the lights.
    • Begin with the light that was placed as the last. If you are uncertain, start from the topmost one.
  10. Christmas Tree Teardown: 10 단계, 이미지 1/2 Christmas Tree Teardown: 10 단계, 이미지 2/2
    • Before you run around barefoot in celebration, clean up.
    • Check amongst the floor sweepings for any surface mount components components which may have gone missing during assembly, and carefully put them aside
    • The christmas tree is disassembled!
    • Check whether your local council will take your old Christmas tree for recycling. Burning is not recommended on account of the CO2 emissions it would produce.
    • Thank you for reading, hope you are having a happy holiday.
    • Fix yourself a wonderful New Year in 2019!
baq
회원 가입일: 10/14/09
305 평판
안내서 3개 작성하였습니다
댓글 한 개
skuirel sed it good!
Kyle Wiens - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 8,625
