주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Cisco 878 Integrated Services Router 수리는 저희 서비스 설명서를 사용하십시오.
  1. Cisco 878 Integrated Services Router Teardown, Remove the two screws on back side: 1 단계, 이미지 1/3 Cisco 878 Integrated Services Router Teardown, Remove the two screws on back side: 1 단계, 이미지 2/3 Cisco 878 Integrated Services Router Teardown, Remove the two screws on back side: 1 단계, 이미지 3/3
    • Only trained and qualified personnel should be allowed to install, replace, or service this equipment!
    • During this procedure, wear grounding wrist straps to avoid ESD damage to the card. Do not directly touch the backplane with your hand or any metal tool, or you could shock yourself!
    • Make sure that the power switch is turned to standby and that the power supply cable is disconnected. Disconnect all cables from the router back panel.
    • Use the Phillips #1 Screwdriver to remove the two screws on back side of the device.
  2. Cisco 878 Integrated Services Router Teardown, Remove top cover: 2 단계, 이미지 1/3 Cisco 878 Integrated Services Router Teardown, Remove top cover: 2 단계, 이미지 2/3 Cisco 878 Integrated Services Router Teardown, Remove top cover: 2 단계, 이미지 3/3
    • 1. Gently push the top cover of the router away from you.
    • 2. Lift it up top cover from the bottom of the router.
    • 3. Remove top cover from the device.
    • Place the router bottom on an antistatic mat.
  3. Cisco 878 Integrated Services Router Teardown, Remove the three screws on front side: 3 단계, 이미지 1/2 Cisco 878 Integrated Services Router Teardown, Remove the three screws on front side: 3 단계, 이미지 2/2
    • Use the Phillips #1 Screwdriver to remove the three screws on front side of the device.
  4. Cisco 878 Integrated Services Router Teardown, Remove the inner metal shield: 4 단계, 이미지 1/3 Cisco 878 Integrated Services Router Teardown, Remove the inner metal shield: 4 단계, 이미지 2/3 Cisco 878 Integrated Services Router Teardown, Remove the inner metal shield: 4 단계, 이미지 3/3
    • 1. Gently lift up inner metal shield from the bottom of the router.
    • 2. Remove inner metal shield from the device (see the anchors on the picture).
    • Be careful and do not distort the plates!
  5. Cisco 878 Integrated Services Router Teardown, Remove  StrataFlash Memory module: 5 단계, 이미지 1/3 Cisco 878 Integrated Services Router Teardown, Remove  StrataFlash Memory module: 5 단계, 이미지 2/3 Cisco 878 Integrated Services Router Teardown, Remove  StrataFlash Memory module: 5 단계, 이미지 3/3
    • 1. Place your fingers on the levers at the two sides of the slot, and push open.
    • 2. Firmly pull the release lever away from the module until the module pops up.
    • 3. You can then remove the module from the module slot.
  6. Cisco 878 Integrated Services Router Teardown, Remove black and silver screws: 6 단계, 이미지 1/1
    • 1. Use the Phillips #1 Screwdriver to remove the black screw.
    • 2. Use the Phillips #1 Screwdriver to remove the silver screw as shown on picture.
    • You should remove just only one silver screw - the second one is holding just cooling plate.
  7. Cisco 878 Integrated Services Router Teardown, Remove CPU module: 7 단계, 이미지 1/3 Cisco 878 Integrated Services Router Teardown, Remove CPU module: 7 단계, 이미지 2/3 Cisco 878 Integrated Services Router Teardown, Remove CPU module: 7 단계, 이미지 3/3
    • Gently pull the module up to disconnect two connectors underneath.
    • Be careful and don't damage 4-pin connector (marked RED).
  8. Cisco 878 Integrated Services Router Teardown, Remove screws holding motherboard: 8 단계, 이미지 1/1
    • Use the Phillips #1 Screwdriver to remove the two screws holding the motherboard.
    • When putting screws back, don't use force - threads are made of plastic!
  9. Cisco 878 Integrated Services Router Teardown, Remove motherboard from the case: 9 단계, 이미지 1/3 Cisco 878 Integrated Services Router Teardown, Remove motherboard from the case: 9 단계, 이미지 2/3 Cisco 878 Integrated Services Router Teardown, Remove motherboard from the case: 9 단계, 이미지 3/3
    • 1. Gently lift up the board to release plastic locks.
    • 2. Gently pull the board away from backside panel (to release metal shielding locks around connectors).
    • 3. Remove board from the case.
  10. Cisco 878 Integrated Services Router Teardown, Teardown complete: 10 단계, 이미지 1/1
    • Parts and pieces:
    • Top cover
    • Inner metal shield cover
    • Bottom part of case with metal shielding
    • Motherboard
    • SHDSL Filter Module board
    • StrataFlash Memory Module
    • 1 black screw, 1 silver long screw (1 is still on SHDSL Filter Module board), 7 silver screws
  11. Cisco 878 Integrated Services Router Teardown, Motherboard extension slots: 11 단계, 이미지 1/1
    • mini-PCI slot for WLAN card
    • DRAM socket for additional RAM Memory Module
    • Slot for additional StrataFlash Memory Module (4MB module installed)
    • Two connectors for SHDSL Filter Module board
Jiri Altman
회원 가입일: 05/03/16
1,515 평판
안내서 9개 작성하였습니다
4k20 Repair Team 4k20 Repair Team 회원
Community
2 회원들
안내서 17개 작성하였습니다
댓글 3개
Sorry mate, that's not a CPU board but a SHDSL line filter. CPU is the biggest, center chip (freescale)
karmansan - 답글
Thx for info! I will update my guide accordingly...
Jiri Altman -
is it possible to add wireless capability to this router by installing a wifi card in the empty mini PCI slot?
timber poodle - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 15
30일 전: 26
전체 시간: 3,626
