주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Commodore 1341 Joystick 수리는 저희 서비스 설명서를 사용하십시오.
  1. Commodore 1341 Joystick Teardown, Commodore 1341 Joystick Teardown: 1 단계, 이미지 1/1
    • Introduced in 1984, the Commodore 1341 joystick was designed for use with the Commodore range of computers including the Commodore 64, 128, VIC20 and Commodore Plus4.
    • This joystick connects to the retro computers using a 9 pin connection.
  2. Commodore 1341 Joystick Teardown: 2 단계, 이미지 1/3 Commodore 1341 Joystick Teardown: 2 단계, 이미지 2/3 Commodore 1341 Joystick Teardown: 2 단계, 이미지 3/3
    • The joystick is held together by five phillips head screws. One screw is located on the handle and the remaining four are under the base.
    • Once the screws have been removed you can pry the case apart using a flat head screw driver. Just be careful with the base as it is spring loaded and it can fly apart quite easily.
  3. Commodore 1341 Joystick Teardown: 3 단계, 이미지 1/3 Commodore 1341 Joystick Teardown: 3 단계, 이미지 2/3 Commodore 1341 Joystick Teardown: 3 단계, 이미지 3/3
    • You will need to desolder the fire button cables from the board.
    • Pry the case open but watch for the spring. There is also a rubber bung that sits beneath the black rocker shaft.
    • Desolder the cables from the main joystick board and remove all of the components.
    • Now you are ready to clean all of the joystick components and reassemble.
Andy Marsh
회원 가입일: 04/24/10
118 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 18
전체 시간: 7,075
