주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Compaq iPaq Pocket PC 3765 수리는 저희 서비스 설명서를 사용하십시오.
  1. Compaq iPaq Pocket PC 3765 Teardown, Compaq iPaq Pocket PC 3765 Teardown: 1 단계, 이미지 1/1
    • an original ipaq from compaq not hp
    • the teardown is realatively simple (PS: simply is not always easy)
  2. Compaq iPaq Pocket PC 3765 Teardown: 2 단계, 이미지 1/3 Compaq iPaq Pocket PC 3765 Teardown: 2 단계, 이미지 2/3 Compaq iPaq Pocket PC 3765 Teardown: 2 단계, 이미지 3/3
    • There are four torx screws here
  3. Compaq iPaq Pocket PC 3765 Teardown: 3 단계, 이미지 1/3 Compaq iPaq Pocket PC 3765 Teardown: 3 단계, 이미지 2/3 Compaq iPaq Pocket PC 3765 Teardown: 3 단계, 이미지 3/3
    • Gently pry around the edges to release the cover
    • The battery is glued to the back cover be careful not to damage the fragile ribbon cable
    • fold the back under the front panel and carefully remove the battery connector
  4. Compaq iPaq Pocket PC 3765 Teardown: 4 단계, 이미지 1/2 Compaq iPaq Pocket PC 3765 Teardown: 4 단계, 이미지 2/2
    • x
  5. Compaq iPaq Pocket PC 3765 Teardown: 5 단계, 이미지 1/2 Compaq iPaq Pocket PC 3765 Teardown: 5 단계, 이미지 2/2
    • Disconnect the backlight
    • from the inverter
    • here is an Htc branded processor
    • be sure to pop up the black wire
    • remove the stylus ejector
  6. Compaq iPaq Pocket PC 3765 Teardown: 6 단계, 이미지 1/1
    • Gently pull on the top face while lifting the logic board (will require some force)
    • Be careful of the black wire running along the board
    • Disconnect the screen and digitizer cables being careful not to damage the cable or connector
  7. Compaq iPaq Pocket PC 3765 Teardown: 7 단계, 이미지 1/1
    • two Intel flash chips
  8. Compaq iPaq Pocket PC 3765 Teardown: 8 단계, 이미지 1/3 Compaq iPaq Pocket PC 3765 Teardown: 8 단계, 이미지 2/3 Compaq iPaq Pocket PC 3765 Teardown: 8 단계, 이미지 3/3
    • again putting pressure on the top panel lift the display out of the case
  9. Compaq iPaq Pocket PC 3765 Teardown: 9 단계, 이미지 1/1
    • an htc branded control board
    • (funny I thought it said compaq on the front?)
  10. Compaq iPaq Pocket PC 3765 Teardown: 10 단계, 이미지 1/2 Compaq iPaq Pocket PC 3765 Teardown: 10 단계, 이미지 2/2
    • The final product (destroyed that is)
    • I used NO anti-static precautions, reassembled the device and after finaly getting the video cable to lock in it worked fine
    • PS: the touch panel worked But when i fixed the video cable i knocked it loose and didnt realize it and now i have to fix it (sigh)
josh9623
회원 가입일: 08/27/10
149 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 15
전체 시간: 3,790
