주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. MP3 Player 수리는 저희 서비스 설명서를 사용하십시오.
  1. Cowon iAudio 7 8GB Teardown, Cowon iAudio 7 8GB Teardown: 1 단계, 이미지 1/1
    • The device in original condition.
  2. Cowon iAudio 7 8GB Teardown: 2 단계, 이미지 1/1
    • Removed the back of the case and the PCB screws. I had to drill open one of the case screws as it was stuck.
  3. Cowon iAudio 7 8GB Teardown: 3 단계, 이미지 1/2 Cowon iAudio 7 8GB Teardown: 3 단계, 이미지 2/2
    • All parts disassembled. Second photo shows back side of the PCB.
    • As we can see, the device contains two Samsung 4GB flash chips along with a K4M28163PH-BG75 memory controller.
    • A Telechips TCC771L as main CPU.
    • A PCF50606HN battery/power management chip.
[deleted]
회원 가입일: 03/24/14
210 평판
안내서 1개 작성함
댓글 3개
2011music my songs
Tong Thao - 답글
Hi! Could you, please, say what the type of display is there?
tikhonte - 답글
If anybody needs a new battery, try this: 3.7V polymer lithium battery 503060 or 053060
The number means the dimensions (5 x 30 x 60mm) The first number is often in 1/10mm
You’d need to solder the original cable to the battery or cables though.
Maybe you want to leave a comment here if this was helpful: adahnsplace.blogspot.com
Endre Sutus - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 14
30일 전: 25
전체 시간: 4,368
