주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Datatronics Discovery 2400CM 수리는 저희 서비스 설명서를 사용하십시오.
  1. Datatronics Discovery 2400CM Teardown, remove front cover: 1 단계, 이미지 1/3 Datatronics Discovery 2400CM Teardown, remove front cover: 1 단계, 이미지 2/3 Datatronics Discovery 2400CM Teardown, remove front cover: 1 단계, 이미지 3/3
    • The front is attached to the body with 2 latches.
    • Using the spudger, open a latch on one side.
    • Open the latch on the other side next to detach the front.
  2. Datatronics Discovery 2400CM Teardown, remove back cover: 2 단계, 이미지 1/2 Datatronics Discovery 2400CM Teardown, remove back cover: 2 단계, 이미지 2/2
    • The back cover is attached to the body the same way as the front.
    • Open both latches to detach to back cover.
  3. Datatronics Discovery 2400CM Teardown, remove board from housing: 3 단계, 이미지 1/3 Datatronics Discovery 2400CM Teardown, remove board from housing: 3 단계, 이미지 2/3 Datatronics Discovery 2400CM Teardown, remove board from housing: 3 단계, 이미지 3/3
    • The board is attached to the body with 2 screws. The screws are hidden under "warranty voidance" stickers.
    • Remove the stickers so you can unscrew the screws.
    • Slide the board from the body.
  4. Datatronics Discovery 2400CM Teardown, overview: 4 단계, 이미지 1/3 Datatronics Discovery 2400CM Teardown, overview: 4 단계, 이미지 2/3 Datatronics Discovery 2400CM Teardown, overview: 4 단계, 이미지 3/3
    • Overview of the front and back of the board, as well as a detailed view of the label.
knipwim
회원 가입일: 09/01/18
8,625 평판
안내서 31개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 12
전체 시간: 934
