주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Dell Inspiron 1750 수리는 저희 서비스 설명서를 사용하십시오.
  1. Dell Inspiron 1750 Teardown, Battery: 1 단계, 이미지 1/2 Dell Inspiron 1750 Teardown, Battery: 1 단계, 이미지 2/2
    • Unplug the laptop before changing the battery to avoid electric shock.
    • Place the laptop on a flat stable surface.
    • Flip the laptop over so the underside is visible.
  2. Dell Inspiron 1750 Teardown: 2 단계, 이미지 1/2 Dell Inspiron 1750 Teardown: 2 단계, 이미지 2/2
    • Locate the battery lock switch.
    • Slide the lock switch to the left (away from the lock symbol).
    • Slide the battery out away from the laptop.
  3. Dell Inspiron 1750 Teardown, Dell Inspiron 1750 Teardown: 3 단계, 이미지 1/1
    • Separate the screws by size and head type. Be sure to keep them in a safe place.
    • Remove the sixteen 2mm Phillips #00 screws from the bottom of the laptop.
    • Remove the two 2mm Phillips #0 screws from the hard drive port.
  4. Dell Inspiron 1750 Teardown: 4 단계, 이미지 1/3 Dell Inspiron 1750 Teardown: 4 단계, 이미지 2/3 Dell Inspiron 1750 Teardown: 4 단계, 이미지 3/3
    • Keep your hand pressed firmly on the back panel to prevent it from falling.
    • Flip the laptop over horizontally and open up the lid.
    • Insert the tip of the plastic opening tool into the upper left corner of the panel.
    • Keeping its tip under the top panel, slide the plastic opening tool around the panel until the panel is completely loose. Next gently remove the panel.
    • Remove the four 2mm Phillips #0 screws at the top of the keyboard.
    • Slide the plastic opening tool around the keyboard until the keyboard is completely loose. Gently remove the keyboard.
  5. Dell Inspiron 1750 Teardown: 5 단계, 이미지 1/3 Dell Inspiron 1750 Teardown: 5 단계, 이미지 2/3 Dell Inspiron 1750 Teardown: 5 단계, 이미지 3/3
    • Do not lift the keyboard completely free to avoid damaging its connections to the laptop interior.
    • Locate the small black latch attached to blue tape.
    • Lift the small latch with your finger and pull the blue tape from its port.
    • Slide the keyboard away from the mousepad and set it aside.
  6. Dell Inspiron 1750 Teardown: 6 단계, 이미지 1/3 Dell Inspiron 1750 Teardown: 6 단계, 이미지 2/3 Dell Inspiron 1750 Teardown: 6 단계, 이미지 3/3
    • Always pull wires from their plastic ends, not their cables, to avoid wire damage.
    • Locate the three wires in the top left corner of the metal panel.
    • Use the spudger to push the two cables out of their ports.
    • Pull the blue tab directly up to remove middle wire.
  7. Dell Inspiron 1750 Teardown: 7 단계, 이미지 1/2 Dell Inspiron 1750 Teardown: 7 단계, 이미지 2/2
    • Remove the three 1mm Phillips #00 screws on the metal plate.
    • Lift the black cover and slide the blue tab away from the cover.
  8. Dell Inspiron 1750 Teardown: 8 단계, 이미지 1/3 Dell Inspiron 1750 Teardown: 8 단계, 이미지 2/3 Dell Inspiron 1750 Teardown: 8 단계, 이미지 3/3
    • Gently remove the three grey wires from the metal tabs.
    • Insert the tip of the plastic opening tool into the bottom left corner of the panel.
    • Gently lift off the top metal panel.
첨부 문서
Jordan Nedbailo
회원 가입일: 04/07/14
687 평판
안내서 2개 작성하였습니다
Cal Poly, Team 6-3, Forte Spring 2014 Cal Poly, Team 6-3, Forte Spring 2014 회원
CPSU-FORTE-S14S6G3
5 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 15
전체 시간: 20,269
