해당 분해도는 작업 중 입니다 – 최신 변경 사항을 보려면 주기적으로 다시 로드 하십시오!
해당 분해도에 사용된 도구
소개
This is a complete teardown of the Dell Quietkey SK-8000 Keyboard.
  1. Flip the keyboard over to expose 8 screws. Use a Phillips screwdriver to unscrew and remove each screw.
    • Flip the keyboard over to expose 8 screws.
    • Use a Phillips screwdriver to unscrew and remove each screw.
  2. Lift the keyboard upward from the bottom. Do not pull too hard when lifting the base. Be careful not to destroy the wires connecting to the base of the keyboard.
    • Lift the keyboard upward from the bottom.
    • Do not pull too hard when lifting the base. Be careful not to destroy the wires connecting to the base of the keyboard.
    • Use a Phillips screwdriver to remove the remaining ten screws on the aluminum plate.
  3. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  4. Carefully lift each part out. Each part should lift out very easily after the screws are removed. Carefully lift each part out. Each part should lift out very easily after the screws are removed. Carefully lift each part out. Each part should lift out very easily after the screws are removed.
    • Carefully lift each part out. Each part should lift out very easily after the screws are removed.
  5. The keyboard controller is seen to be a Siltek R4462.
    • The keyboard controller is seen to be a Siltek R4462.
Ion
회원 가입일: 2015년 09월 29일
470 평판
안내서 3개 작성하였습니다
Cal Poly, Team 10-5, Green Fall 2015 Cal Poly, Team 10-5, Green Fall 2015 회원
CPSU-GREEN-F15S10G5
3 회원들
안내서 4개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 24
전체 시간: 260
