주요 콘텐츠로 건너뛰기
필요한 것
동영상 개요
해당 분해도는 수리 안내서가 아닙니다. Dell XPS 13 9370 수리는 저희 서비스 설명서를 사용하십시오.
  1. Dell XPS 13 9370 Teardown, Dell XPS 13 9370 Teardown: 1 단계, 이미지 1/3 Dell XPS 13 9370 Teardown, Dell XPS 13 9370 Teardown: 1 단계, 이미지 2/3 Dell XPS 13 9370 Teardown, Dell XPS 13 9370 Teardown: 1 단계, 이미지 3/3
    • Insert wisdom here.
IT FIX
회원 가입일: 10/16/17
6,340 평판
안내서 74개 작성하였습니다
댓글 9개
nice…. hope soon the whole step would be upload so I can repair my water damaged in laptop screen
m.aiman_90 - 답글
Too bad you didn’t take the heatsink and cooler off, to have a look at the cpu.
Takk - 답글
will there be a 9370 teardown? The one up now only shows basic steps but I need to replace the palm rest body and would appreciate one!
steveen park - 답글
Same, please let me know if you found a way to do this.
Stephen Spencer -
Is the touch screen connector on the motherboard present also on the non-touch XPS?
Raffaele T. - 답글
Anyone know if the 60wh battery is compatible with a 9343/9350 model?
David Moheban - 답글
I have a 9370 with an 8GB RAM and would like to know if the RAM could be upgraded. I’m aware there is not going to be any extra slots. Are the RAM soldered or inserted in a slot just like the SSD ?
Sarath Babu Nagarajan - 답글
Hello, can the screen be replaced without replacing the entire top assembly?
David Gutierrez Armayor - 답글
hello, i have Dell XPS 9370 no touchscreen FHD, can I replace it with touch screen 4k? the connectors are the same or not?
thanks.
EMRAH - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 20
30일 전: 149
전체 시간: 35,435
