주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. DirectPower DE157 Cordless drill-screwdriver 수리는 저희 서비스 설명서를 사용하십시오.
  1. DirectPower DE157 Cordless drill-screwdriver Teardown, DirectPower DE157 Cordless drill-screwdriver Teardown: 1 단계, 이미지 1/2 DirectPower DE157 Cordless drill-screwdriver Teardown, DirectPower DE157 Cordless drill-screwdriver Teardown: 1 단계, 이미지 2/2
    • The driver kit.
    • This is a more-or-less no-name cordless screwdriver/drill kit, but its construction more or less matches most of these devices.
  2. DirectPower DE157 Cordless drill-screwdriver Teardown: 2 단계, 이미지 1/3 DirectPower DE157 Cordless drill-screwdriver Teardown: 2 단계, 이미지 2/3 DirectPower DE157 Cordless drill-screwdriver Teardown: 2 단계, 이미지 3/3
    • The charger consist of a standard wallwart, output 14.4V 350mA, along with a little block (weighing nothing at all) to connect to one of the battery packs.
    • To open the charger block, unscrew three #1 Phillips screws.
  3. DirectPower DE157 Cordless drill-screwdriver Teardown: 3 단계, 이미지 1/2 DirectPower DE157 Cordless drill-screwdriver Teardown: 3 단계, 이미지 2/2
    • After lifting off the bottom, the PCB is exposed, and you can lift it out of the charger block along with the battery contacts. On the PCB we find:
    • A diode to protect against reverse current.
    • An LED and resistor that is on so long as the box gets power.
    • A giant 10 Ohm resistor to slightly current-limit the charge, and across which the green led and resistor are placed -- this will therefore light up as long as significant current passes to the battery.
  4. DirectPower DE157 Cordless drill-screwdriver Teardown: 4 단계, 이미지 1/2 DirectPower DE157 Cordless drill-screwdriver Teardown: 4 단계, 이미지 2/2
    • One of the two battery packs. To open, remove
    • Four #1 Phillips screws.
  5. DirectPower DE157 Cordless drill-screwdriver Teardown: 5 단계, 이미지 1/3 DirectPower DE157 Cordless drill-screwdriver Teardown: 5 단계, 이미지 2/3 DirectPower DE157 Cordless drill-screwdriver Teardown: 5 단계, 이미지 3/3
    • After removing the screws, turn right side up again and lift off the plastic cover, exposing 12 NiCd cells in a string, and nothing else.
    • Note that there is room on the right side for three more cells, which would make a 18V battery pack.
    • Especially cheaper makers usually have versions for 7.2V/9.6V/12/14.4/18V all using the same plastic, just more or less cells and a different motor.
Jasper
회원 가입일: 05/02/10
136 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 2,436
