주요 콘텐츠로 건너뛰기
Disassembling of HP 625 Laptop Teardown Guide
필요한 것
  1. Disassembling of HP 625 Laptop Teardown Guide, Teardown Guide: 1 단계, 이미지 1/1
    • Overview of Hp 625.
  2. Disassembling of HP 625 Laptop Teardown Guide: 2 단계, 이미지 1/1
    • Front View of Hp 625.
  3. Disassembling of HP 625 Laptop Teardown Guide: 3 단계, 이미지 1/1
    • Removal of Hp 625 Battery.
  4. Disassembling of HP 625 Laptop Teardown Guide: 4 단계, 이미지 1/1
    • Removing of Hp 625 Battery.
  5. Disassembling of HP 625 Laptop Teardown Guide: 5 단계, 이미지 1/1
    • Hp 625 Battery Removed.
  6. Disassembling of HP 625 Laptop Teardown Guide: 6 단계, 이미지 1/1
    • Unscrewing Hp 625 Service Door (4 Screws).
  7. Disassembling of HP 625 Laptop Teardown Guide: 7 단계, 이미지 1/1
    • Removing Hp 625 Service Door.
  8. Disassembling of HP 625 Laptop Teardown Guide: 8 단계, 이미지 1/1
    • Hp 625 Service Door Removed.
  9. Disassembling of HP 625 Laptop Teardown Guide: 9 단계, 이미지 1/1
    • Unscrewing Hp 625 HDD, (3 Screws).
  10. Disassembling of HP 625 Laptop Teardown Guide: 10 단계, 이미지 1/1
    • Removing of Hp 625 HDD, (Gently Slide).
  11. Disassembling of HP 625 Laptop Teardown Guide: 11 단계, 이미지 1/1
    • Hp 625 HDD Removed.
  12. Disassembling of HP 625 Laptop Teardown Guide: 12 단계, 이미지 1/1
    • Unscrewing of Hp 625 DVD Drive, (1 Screw)
  13. Disassembling of HP 625 Laptop Teardown Guide: 13 단계, 이미지 1/1
    • Removing of Hp 625 DVD Drive, (Carefully Slid).
  14. Disassembling of HP 625 Laptop Teardown Guide: 14 단계, 이미지 1/1
    • Hp 625 DVD Drive Removed.
  15. Disassembling of HP 625 Laptop Teardown Guide: 15 단계, 이미지 1/1
    • Removing of Hp 625 DDR3 RAM, (Together With Two Hands Expand The Clips a little).
  16. Disassembling of HP 625 Laptop Teardown Guide: 16 단계, 이미지 1/1
    • Hp 625 DDR3 RAM Removed, ( Be sure not to Touch The Gold Plated Pinouts).
  17. Disassembling of HP 625 Laptop Teardown Guide: 17 단계, 이미지 1/1
    • Unscrewing of Hp 625 Keyboard, (6 Screws Noted By Keyboard icon).
  18. Disassembling of HP 625 Laptop Teardown Guide: 18 단계, 이미지 1/1
    • Removing of Hp 625 Keyboard Flex Cable, (Gently Release The Locking Mechanism).
  19. Disassembling of HP 625 Laptop Teardown Guide: 19 단계, 이미지 1/1
    • Hp 625 Keyboard Removed.
  20. Disassembling of HP 625 Laptop Teardown Guide: 20 단계, 이미지 1/1
    • Disconnecting of Hp 625 Power Flex Cable From Connector, ( Fairly Unlock The Locking Mechanism).
  21. Disassembling of HP 625 Laptop Teardown Guide: 21 단계, 이미지 1/1
    • Hp 625 Power Flex Cable Disconnected.
  22. Disassembling of HP 625 Laptop Teardown Guide: 22 단계, 이미지 1/1
    • Unlocking of Hp 625 Palm Rest, Through The HDD Bay.
  23. Disassembling of HP 625 Laptop Teardown Guide: 23 단계, 이미지 1/1
    • Disconnecting Touch Pad Flex Cable and Removing of Hp 625 Palm Rest.
  24. Disassembling of HP 625 Laptop Teardown Guide: 24 단계, 이미지 1/1
    • Hp 625 Palm Rest Removed.
  25. Disassembling of HP 625 Laptop Teardown Guide: 25 단계, 이미지 1/1
    • Unscrewing of Hp 625 System Casein, (16 or More Additional Screws Verify Very Well For Additional Screws Needed To Be Unscrewed Before Removing The Casein).
  26. Disassembling of HP 625 Laptop Teardown Guide: 26 단계, 이미지 1/1
    • Removing of Hp 625 Front Casein, (Firmly Pry the Casein, Starting from Any Edge).
  27. Disassembling of HP 625 Laptop Teardown Guide: 27 단계, 이미지 1/1
    • Hp 625 Front Casein Removed.
  28. Disassembling of HP 625 Laptop Teardown Guide: 28 단계, 이미지 1/1
    • Unscrewing of Hp 625 Thermal Fan, (1 Screw).
  29. Disassembling of HP 625 Laptop Teardown Guide: 29 단계, 이미지 1/1
    • Hp 625 Thermal Fan Removed.
  30. Disassembling of HP 625 Laptop Teardown Guide: 30 단계, 이미지 1/1
    • Unscrewing of Hp 625 Thermal Conductive Heatsink, (6 Screws).
  31. Disassembling of HP 625 Laptop Teardown Guide: 31 단계, 이미지 1/1
    • Hp 625 Thermal Conductive Heatsink Removed.
  32. Disassembling of HP 625 Laptop Teardown Guide: 32 단계, 이미지 1/1
    • Unlocking of Hp 625 AMD Processor From Socket, (Anti-Clockwise).
  33. Disassembling of HP 625 Laptop Teardown Guide: 33 단계, 이미지 1/1
    • Hp 625 AMD Processor Removed.
  34. Disassembling of HP 625 Laptop Teardown Guide: 34 단계, 이미지 1/1
    • Disconnecting of Hp 625 Wi-Fi Cables From Wireless Card.
  35. Disassembling of HP 625 Laptop Teardown Guide: 35 단계, 이미지 1/1
    • Hp 625 Wi-Fi Cables Disconnected.
  36. Disassembling of HP 625 Laptop Teardown Guide: 36 단계, 이미지 1/1
    • Disconnecting of Hp 625 HDD Card From Motherboard.
  37. Disassembling of HP 625 Laptop Teardown Guide: 37 단계, 이미지 1/1
    • Disconnecting All Cables of Hp 625 Connected To Motherboard.
  38. Disassembling of HP 625 Laptop Teardown Guide: 38 단계, 이미지 1/1
    • Unscrewing Hp 625 Motherboard.
  39. Disassembling of HP 625 Laptop Teardown Guide: 39 단계, 이미지 1/1
    • Removing of Hp 625 Motherboard.
  40. Disassembling of HP 625 Laptop Teardown Guide: 40 단계, 이미지 1/1
    • Hp 625 Motherboard Removed.
  41. Disassembling of HP 625 Laptop Teardown Guide: 41 단계, 이미지 1/1
    • Complete Disassembled Parts and Components of Hp 625.
  42. Disassembling of HP 625 Laptop Teardown Guide: 42 단계, 이미지 1/1
    • 'Reparatur ist edel
결론
다른 9명이 해당 안내서를 완성하였습니다.
samuel
회원 가입일: 06/09/13
391 평판
안내서 1개 작성함
댓글 3개
You mentioned there are 6 keyboard screws. I can find only five. Can you be more specific (detailed) in where these screws exactly are. Thanks
simakos71 - 답글
Hello Simakos71, follow this YouTube link: https://youtu.be/91JQ596T0og to know strategic places the screws are located.
samuel -
Whats a good way to follow i really want to be repairing but i need your advice on how to start thanks
engiengimib@gmail.com
Ibrahim Musa Bello - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 9
30일 전: 23
전체 시간: 11,793
