주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Dual USB Connector 수리는 저희 서비스 설명서를 사용하십시오.
  1. MSI Dual USB Port Bracket Teardown, MSI Dual USB Port Bracket Teardown: 1 단계, 이미지 1/1
    • This part of the bracket consists of the circuit board enclosed in a plastic housing, which we will tear down in the next step.
    • These connectors plug into the USB headers on the motherboard.
  2. MSI Dual USB Port Bracket Teardown: 2 단계, 이미지 1/2 MSI Dual USB Port Bracket Teardown: 2 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Phillips #1 Screwdriver
    $5.49
    구매
    • Use a Phillips #1 screwdriver to remove the four screws from the white casing and the two screws from the metal bracket.
    • On the bottom of the circuit board, the pins that hold its components can cut skin.
    • The two USB 2.0 ports.
    • The four LED lights, which light up depending on the activity of the USB ports.
  3. MSI Dual USB Port Bracket Teardown: 3 단계, 이미지 1/1
    • Raise the three connectors from the case and it's out!
    • The connectors highlighted in red lead to the wires that connect the bracket to the motherboard.
    • The two USB ports.
    • The LED activity lights.
samhnri
회원 가입일: 04/07/10
415 평판
안내서 2개 작성하였습니다
댓글 한 개
Why does it need its owe usb header just for the LED's.
Rick Acker - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 22
전체 시간: 7,778
