주요 콘텐츠로 건너뛰기
해당 분해도는 작업 중 입니다 – 최신 변경 사항을 보려면 주기적으로 다시 로드 하십시오!
필요한 것
  1. DualShock 3 Teardown, DualShock 3 Teardown: 1 단계, 이미지 1/3 DualShock 3 Teardown, DualShock 3 Teardown: 1 단계, 이미지 2/3 DualShock 3 Teardown, DualShock 3 Teardown: 1 단계, 이미지 3/3
    • First step you would have to do would be to unscrew five screws from the back of the controller.
  2. DualShock 3 Teardown: 2 단계, 이미지 1/2 DualShock 3 Teardown: 2 단계, 이미지 2/2
    • After you unscrewed all five screws in the back, next you're going to have to gently pull both of the controller sides apart and it will come straight off.
  3. DualShock 3 Teardown: 3 단계, 이미지 1/2 DualShock 3 Teardown: 3 단계, 이미지 2/2
    • Then you have to take off the battery and you have to be very careful, if you break the battery your controller wont work.
  4. DualShock 3 Teardown: 4 단계, 이미지 1/1
    • There are two screws and you are going to unscrew one from above and the bottom.
  5. DualShock 3 Teardown: 5 단계, 이미지 1/2 DualShock 3 Teardown: 5 단계, 이미지 2/2
    • Then you are going to take off these analog sticks.
    • ( You can put the analog sticks back on )
  6. DualShock 3 Teardown: 6 단계, 이미지 1/2 DualShock 3 Teardown: 6 단계, 이미지 2/2
    • Then you will be able to lift right off the other stuff that will be left.
  7. DualShock 3 Teardown: 7 단계, 이미지 1/1
    • and now you have all your parts of your DualShock 3 PS3 controller all scattered, to put it back together you would just have to follow the steps backwards.
Diego Figueroa
회원 가입일: 11/07/16
223 평판
안내서 1개 작성함
댓글 2개
Thanks for the contribution. This seems to be a Chinese fake model though. None of the board features look neither VX model. No white plastic frame, battery not grey, and SONY logo on the front "seems" to be not aligned, hence the fake model. So many Amazon and Ebay fakes at $20-$30 bearing the SONY registered trademarks, its become a plague. "P2" controllers and fake DS3's are identical, other than the logos. One must be careful and ask for pictures of the exact controller being sold, and if possible board model. If no returns, stay away.
http://www.psdevwiki.com/ps3/DualShock_3
DualshockUser - 답글
Yeah this is a fake model. Evident by the blue battery.
Tengku Elzafir Habsjah - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 41
전체 시간: 7,972
