주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. DualShock 4 수리는 저희 서비스 설명서를 사용하십시오.
  1. DualShock 4 Teardown, Open the chassis of the controller: 1 단계, 이미지 1/3 DualShock 4 Teardown, Open the chassis of the controller: 1 단계, 이미지 2/3 DualShock 4 Teardown, Open the chassis of the controller: 1 단계, 이미지 3/3
    • Begin by removing the screws in the back of the controller.
  2. DualShock 4 Teardown, Remove analog sticks and motors: 2 단계, 이미지 1/2 DualShock 4 Teardown, Remove analog sticks and motors: 2 단계, 이미지 2/2
    • Remove the analog sticks and motors.
  3. DualShock 4 Teardown, Remove the top layer PCB: 3 단계, 이미지 1/1
    • Remove the top layer PCB. The PCB must be popped out of place and then angled in such a way that the trigger buttons at the top of the controller slide out of their slots.
  4. DualShock 4 Teardown, Remove the second layer PCB: 4 단계, 이미지 1/1
    • Remove the second layer PCB. This simply pops out of place.
  5. DualShock 4 Teardown, Remove the battery: 5 단계, 이미지 1/1
    • Flip over the second layer PCB. Remove the battery from its holder.
  6. DualShock 4 Teardown, Remove the light assembly: 6 단계, 이미지 1/3 DualShock 4 Teardown, Remove the light assembly: 6 단계, 이미지 2/3 DualShock 4 Teardown, Remove the light assembly: 6 단계, 이미지 3/3
    • Unscrew the two screws holding the light assembly together. Once the screws are undone, the parts of the assembly can be pulled out.
  7. DualShock 4 Teardown, Remove the USB module: 7 단계, 이미지 1/2 DualShock 4 Teardown, Remove the USB module: 7 단계, 이미지 2/2
    • Unscrew the two screws holding down the USB module.
Joshua Wong
회원 가입일: 11/28/18
265 평판
안내서 1개 작성함
댓글 6개
Thanks this was so helpful because every time I do this I break it like literally break the plastic
nodachi Galaxy poison - 답글
Do you know where I can get broken PS4 controllers?
Chane Akwau Jones - 답글
it doesn’t come out like that. upon opening the chassis, everything is stuck to the top part of the controller, not the bottom part.
Dennis Hasford - 답글
First time fixing sticking buttons my triangle button and ps button stick hopefully this works and am able to put back together
Tkuball - 답글
This video on how to open a ps4 controller should help you too : https://youtu.be/9Chgw4sRTzs
Repair & Resell - 답글
댓글 쓰기
조회 통계:
24 시간 전: 21
7일 전: 136
30일 전: 691
전체 시간: 64,625
