주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. DualShock 4 수리는 저희 서비스 설명서를 사용하십시오.
  1. DualShock 4 Teardown, Open the chassis of the controller: 1 단계, 이미지 1/3 DualShock 4 Teardown, Open the chassis of the controller: 1 단계, 이미지 2/3 DualShock 4 Teardown, Open the chassis of the controller: 1 단계, 이미지 3/3
    • Begin by removing the screws in the back of the controller.
    you need to open up the 2 tabs near the USB port to removed the top cover after removing the 4 screws in the back.
    Clarence Kong - 답글
    This is nowhere near enough information. Removing the four screws gets nothing off, and no idea what “2 tabs” the above comment is talking about. The controller would stay together completely with or without the screws…
    Manjushri - 답글
    right away this guide give you nothing in terms of actual information on actually taking apart the duel shock 4
    Eden - 답글
  2. DualShock 4 Teardown, Remove analog sticks and motors: 2 단계, 이미지 1/2 DualShock 4 Teardown, Remove analog sticks and motors: 2 단계, 이미지 2/2
    • Remove the analog sticks and motors.
  3. DualShock 4 Teardown, Remove the top layer PCB: 3 단계, 이미지 1/1
    • Remove the top layer PCB. The PCB must be popped out of place and then angled in such a way that the trigger buttons at the top of the controller slide out of their slots.
  4. DualShock 4 Teardown, Remove the second layer PCB: 4 단계, 이미지 1/1
    • Remove the second layer PCB. This simply pops out of place.
  5. DualShock 4 Teardown, Remove the battery: 5 단계, 이미지 1/1
    • Flip over the second layer PCB. Remove the battery from its holder.
  6. DualShock 4 Teardown, Remove the light assembly: 6 단계, 이미지 1/3 DualShock 4 Teardown, Remove the light assembly: 6 단계, 이미지 2/3 DualShock 4 Teardown, Remove the light assembly: 6 단계, 이미지 3/3
    • Unscrew the two screws holding the light assembly together. Once the screws are undone, the parts of the assembly can be pulled out.
  7. DualShock 4 Teardown, Remove the USB module: 7 단계, 이미지 1/2 DualShock 4 Teardown, Remove the USB module: 7 단계, 이미지 2/2
    • Unscrew the two screws holding down the USB module.
    Nice now my ps4 controller works thank you
    Maxem - 답글
Joshua Wong
회원 가입일: 11/28/18
265 평판
안내서 1개 작성함
댓글 6개
Thanks this was so helpful because every time I do this I break it like literally break the plastic
nodachi Galaxy poison - 답글
Do you know where I can get broken PS4 controllers?
Chane Akwau Jones - 답글
it doesn’t come out like that. upon opening the chassis, everything is stuck to the top part of the controller, not the bottom part.
Dennis Hasford - 답글
First time fixing sticking buttons my triangle button and ps button stick hopefully this works and am able to put back together
Tkuball - 답글
This video on how to open a ps4 controller should help you too : https://youtu.be/9Chgw4sRTzs
Repair & Resell - 답글
I’ve got a poblem with the DS4, after spill coffe in it, i clean it and it was working but the problem is with the sensor motion, for example, when you play the last of us 1, when the shake icon appears in the screen, nothing happen with de DS4
yagzide - 답글
댓글 쓰기
조회 통계:
24 시간 전: 24
7일 전: 137
30일 전: 647
전체 시간: 65,770
