주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Space Heater 수리는 저희 서비스 설명서를 사용하십시오.
  1. Essential Home HC-409 Teardown, Removed protective grill: 1 단계, 이미지 1/3 Essential Home HC-409 Teardown, Removed protective grill: 1 단계, 이미지 2/3 Essential Home HC-409 Teardown, Removed protective grill: 1 단계, 이미지 3/3
    • Remove the grill from corner to corner.
  2. Essential Home HC-409 Teardown, Unscrewed the four screws in the front of the heater: 2 단계, 이미지 1/2 Essential Home HC-409 Teardown, Unscrewed the four screws in the front of the heater: 2 단계, 이미지 2/2
    • Carefully remove the screws and place them aside.
  3. Essential Home HC-409 Teardown, Removed filter cover on the back of the heater: 3 단계, 이미지 1/3 Essential Home HC-409 Teardown, Removed filter cover on the back of the heater: 3 단계, 이미지 2/3 Essential Home HC-409 Teardown, Removed filter cover on the back of the heater: 3 단계, 이미지 3/3
    • As seen in the pictures, set the screwdriver on the edge of the cover and pry it out.
  4. Essential Home HC-409 Teardown, Remove safety sticker: 4 단계, 이미지 1/2 Essential Home HC-409 Teardown, Remove safety sticker: 4 단계, 이미지 2/2
    • Remove sticker in order to open the plastic casing of the heater.
  5. Essential Home HC-409 Teardown, Pry the product in half: 5 단계, 이미지 1/2 Essential Home HC-409 Teardown, Pry the product in half: 5 단계, 이미지 2/2
    • Slowly and carefully pry the plastic casing.
  6. Essential Home HC-409 Teardown, Remove the switch: 6 단계, 이미지 1/2 Essential Home HC-409 Teardown, Remove the switch: 6 단계, 이미지 2/2
    • Apply pressure onto the sides of the switch while pushing it outwards.
  7. Essential Home HC-409 Teardown, Remove fan: 7 단계, 이미지 1/3 Essential Home HC-409 Teardown, Remove fan: 7 단계, 이미지 2/3 Essential Home HC-409 Teardown, Remove fan: 7 단계, 이미지 3/3
    • Unscrew the four screws located in the rear of the device. Remove the fan.
Garland Poon
회원 가입일: 04/03/12
126 평판
안내서 1개 작성함
Cal Poly, Team 14-8, Forte Spring 2012 Cal Poly, Team 14-8, Forte Spring 2012 회원
CPSU-FORTE-S12S14G8
5 회원들
안내서 17개 작성하였습니다
댓글 한 개
I keep having problems with that little part that looks like a pen cap - white plastic. Is it a connector ou a fuse?
Cristina S - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 1,481
