주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Seagate Expansion 수리는 저희 서비스 설명서를 사용하십시오.
  1. Expansion Teardown, Open the cover: 1 단계, 이미지 1/1
    • Using a flat head screwdriver or plastic tool
  2. Expansion Teardown: 2 단계, 이미지 1/1
    • Remove the cover
  3. Expansion Teardown: 3 단계, 이미지 1/1
    • Remove the drive from the case
  4. Expansion Teardown: 4 단계, 이미지 1/1
    • Peel back the shielding
  5. Expansion Teardown: 5 단계, 이미지 1/1
    • Remove the Screw with the #02 screw driver
  6. Expansion Teardown: 6 단계, 이미지 1/2 Expansion Teardown: 6 단계, 이미지 2/2
    • Separate the adapter form the sata port
Dan
회원 가입일: 02/18/19
4,261 평판
안내서 9개 작성하였습니다
댓글 2개
Hello,
I’d like to know if it’s possible to swap in another bigger NAS drive, as I keep my hard drive connected and it might be more durable.
Thank you !
Léana Jiang - 답글
This does appear to be a semi-destructive method. In the picture under step 2, you can see the series of plastic brackets on the cover are snapped. See my pictures here
I had difficulty finding a spot to pry up from. There are 4 lips around the cover that should make it easier. See pics.
Derick Roy - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 14
30일 전: 66
전체 시간: 4,058
