주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Fan 수리는 저희 서비스 설명서를 사용하십시오.
  1. Fan Teardown, Fan Teardown: 1 단계, 이미지 1/1
    • The image displayed to the left of the screen portrays a mobile fan in pristine condition.
  2. Fan Teardown: 2 단계, 이미지 1/1
    • The Guard of the fan is detached from its base due to the effectiveness of a screwdriver.
  3. Fan Teardown: 3 단계, 이미지 1/1
    • As seen in the photograph to the left, the blade of the fan has been removed from its guard.
  4. Fan Teardown: 4 단계, 이미지 1/1
    • The image to the left of the screen displays the guard of the fan conspicuously detached from the fans base. Various screws are spread across the canvas due to their removal.
  5. Fan Teardown: 5 단계, 이미지 1/1
    • We have diverted our focus in disassembling components mainly involved with the fans blade and have begun to focus on "tearing down" the fans motor and shaft.
  6. Fan Teardown: 6 단계, 이미지 1/1
    • The photograph which lays on the left of the screen displays the process of tearing down the initial motor of the mobile fan.
  7. Fan Teardown: 7 단계, 이미지 1/1
    • The casing which covered the interior of the motor has now been removed through the use of a screw to gain access to its interior.
  8. Fan Teardown: 8 단계, 이미지 1/1
    • Now that the casing has been removed, we have gained access to the motor's circuit board.
  9. Fan Teardown: 9 단계, 이미지 1/1
    • We have removed the circuit board from the shell which enclosed it so we may study it further.
  10. Fan Teardown: 10 단계, 이미지 1/1
    • All components of the fan have been disassembled...your task is now complete.
Jeffrey
회원 가입일: 10/19/16
309 평판
안내서 2개 작성하였습니다
댓글 2개
where did you get the fan?
Anrothan - 답글
I’m looking for a replacement fan blade for a reco(unireco) df-12ch fan, I can’t seem to find a website that has them to order.
Renata Weir - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 10
전체 시간: 4,266
