주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Fitbit Charge HR 수리는 저희 서비스 설명서를 사용하십시오.
  1. Fitbit Charge HR Teardown, Remove Screws: 1 단계, 이미지 1/1
    • Take the 4 Screws out of the Sides you will need a T3 star Screw Driver
  2. Fitbit Charge HR Teardown: 2 단계, 이미지 1/2 Fitbit Charge HR Teardown: 2 단계, 이미지 2/2
    • You Pry out the Main board you can see the Metal Hooks
  3. Fitbit Charge HR Teardown: 3 단계, 이미지 1/1
    • You can Then pull out the Screws from around the Screen
Bradley Nelson
회원 가입일: 03/08/16
56 평판
안내서 1개 작성함
댓글 8개
Can the battery be replaced?
Rick - 답글
Mine was just over a year old (barely out of warranty) when it died. The Fitbit folks were kind enough to replace it anyway once I expressed my displeasure. I'd haggle with them a bit before going the DIY route but I'm definitely keeping my old one for spare parts. Hopefully someone will point out an aftermarket battery source before I need to do that.
fragmasterflash - 답글
The screws in mine were Torx T-2, not T-3.
Jake McIvor - 답글
The button is stuck in my ChargeHR. I bought the T3 screwdriver and it is too big. Either the screws are T2 or my screwdriver is too much imprecise.
Anyone fixed a stuck button?
Anderson Maciel - 답글
it definitely not T3 must be T2
Marc Frederick - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 8
30일 전: 22
전체 시간: 23,976
