주요 콘텐츠로 건너뛰기
해당 분해도는 작업 중 입니다 – 최신 변경 사항을 보려면 주기적으로 다시 로드 하십시오!
필요한 것
  1. Fitbit Zip Teardown, Fitbit Zip Teardown: 1 단계, 이미지 1/3 Fitbit Zip Teardown, Fitbit Zip Teardown: 1 단계, 이미지 2/3 Fitbit Zip Teardown, Fitbit Zip Teardown: 1 단계, 이미지 3/3
    • Use your iFixit Pro Tech Knife to slice and pry the different colored front and rear cases apart, as shown
  2. Fitbit Zip Teardown: 2 단계, 이미지 1/2 Fitbit Zip Teardown: 2 단계, 이미지 2/2
    • Remove the logic board/display assembly from the rear case
  3. Fitbit Zip Teardown: 3 단계, 이미지 1/2 Fitbit Zip Teardown: 3 단계, 이미지 2/2
    • Use your knife to slice off the bottom edge of the sticker found here on the rear of the board
  4. Fitbit Zip Teardown: 4 단계, 이미지 1/3 Fitbit Zip Teardown: 4 단계, 이미지 2/3 Fitbit Zip Teardown: 4 단계, 이미지 3/3
    • Use a spudger to gently pry the display away from the logic board
    • Pry softly in each corner of the display, under the black frame
  5. Fitbit Zip Teardown: 5 단계, 이미지 1/1
    • Seems to be it. The display doesn't appear to be separable from the logic board, sadly, making repairability completely out of the question.
    I found a broken Zip on the ground and decided to open it up to see what's inside. The screen is attached via a Zero-Insertion-Force socket, so it should be replaceable. This may be a newer model, but the model number only reads "FB301"
    Final Countdown - 답글
Nathanael
회원 가입일: 02/03/14
953 평판
안내서 2개 작성하였습니다
Beautiful Savior Lutheran Church Beautiful Savior Lutheran Church 회원
Business
1 회원
안내서 3개 작성하였습니다
댓글 2개
The display can be separated from the logic board, just pull it free from the logic board connector.
Yuri Silkin - 답글
My fitbit zip came apart at the seams. I decided to go ahead and clean the screen off since it was coming apart already and the screen looked dusty. Any ideas on how to put it back together? I goes back together and when I hold it everything functions, but I can't get it to stay together. Silicone? Glue? Any suggestions?
sweeney todd - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 2,214
