소개
We got our hands on the fun Flip MinoHD digital video recorder and decided to take a peek inside. We were curious to see what kind of electronics were packed into this simplistic half-aluminum, half-plastic device.
필요한 것
Today's guest has been long overdue for a teardown. So with no further interruptions, we give you the Flip MinoHD in all its glory.
The Flip MinoHD comes packaged in an elegant box that leaves much to the imagination.
Dare we open the box? Dare we do.
Contents of the box:
Flip MinoHD
Quickstart Guide
Soft Protective Case
Wrist Strap
What's better than a Flip MinoHD? A custom-labeled Flip MinoHD!
Eight unique touch-sensitive capacitive buttons (power, play, delete, record and four-way navigation) allow for ease of use.
An mini-HDMI output connector makes it easy to watch video on your HDTV.
There's also a tripod mount that fits any standard tripod.
Begin the disassembly by inserting a plastic opening tool (with the edge pointed toward the aluminum outer case) between the front and outer cases near the bottom of either edge of the MinoHD.
Continue running the plastic opening tool in the seam between the front and outer cases until the left, right, and bottom edges are free.
There's not too much interesting going on inside the front panel.
Capacitive sensors under each of the control symbols (play, back, etc.) provide the logic board with control data, while small LEDs mounted to the logic board (shown in red) under each "button" project light through the front panel to provide their illumination.
Carefully use your fingernail to flip up the retaining flap on the display data cable ZIF socket.
Pull the display data cable out of its socket and remove the display.
Interesting note: On-board video playback is provided by a 2" 960x240 transflective TFT LCD display.
Carefully maneuver the logic board out of the outer case, minding the cables still connecting the two components.
To gain more clearance, remove the small strip of black tape securing the USB ribbon cable to the battery bracket.
Use a pair of tweezers to pull the USB ribbon cable connector away from its socket.
Pull the battery connector out of its socket on the logic board.
Remove the two small silver Phillips screws securing the battery to the outer case.
Use a plastic opening tool to pry the battery up off the outer case.
The MinoHD sips two hours worth of power from the internal 3.7V, 1150 mAh Li-ion battery weighing in at 30 grams (including bracket).
Coincidentally, that's the same battery capacity as the iPhone 3G.
The big players on the logic board include:
A Zoran COACH (camera on a chip) 12 processor featuring real-time lens distortion compensation and noise reduction.
Samsung's 934 KMCMG0000M-B998 8 GB NAND flash memory for video storage.
One Samsung K4T51163QG 512 Mb DDR2 SDRAM chip.
Texas Instruments' TPD12S521 to protect the board from electrostatic discharge through the HDMI port.
Cypress' CY821434-24LXTI PSoC presumably for encoding signals received from the capacitive touch controls.
댓글 9개
Do you have any idea if the Samsung 934 KMCMG0000M-B998 8 GB NAND flash memory can be mounted on an external USB? My Flip cam died, but I would like to extract the final videos.
nigelparry - 답글
nigelparry, did you figure out any way to mount that flash memory anywhere else in order to recover the camer's contents?
My Flip Mino HD stopped working (wouldn't turn on) after just a couple days of taking it out of the box. I followed up to step 13 (removed battery), then reconnected the battery and re-assembled it. I was flabbergasted when it turned on after I pressed the power button. I think disconnecting/reconnecting the battery is what reset it (had tried pressing the 'reset" button in the tripod socket but that had not worked for me). Thanks for saving my Flip from the trash!
This was all not as easy as described. I ended up tearing the data cable and breaking a small piece of the retaining flap, %#*!^@. I had the hardest time trying to get the cable back in.
My problem was that the camera turned on and held a charge just fine, but I couldn't properly reset the thing and it always said it had zero memory space, but zero videos on it. Now it won't turn on, probably bc the video cable is damaged.
And of course, the Flip is no longer made and Cisco has discontinued service. No idea what to do now or where to take it. Any suggestions?
