주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Free Wheelchair Mission GEN 1 수리는 저희 서비스 설명서를 사용하십시오.
  1. Free Wheelchair Mission GEN 1 Teardown, Remove Air Pump: 1 단계, 이미지 1/2 Free Wheelchair Mission GEN 1 Teardown, Remove Air Pump: 1 단계, 이미지 2/2
    • Start by finding the pump on the back of the wheelchair.
    • Remove the screw that holds the pump to the frame with a 10 mm wrench.
  2. Free Wheelchair Mission GEN 1 Teardown, Remove Footrest: 2 단계, 이미지 1/1
    • To remove the footrest, turn it upside-down and use the 10 mm box wrench to take out all four of the screws.
  3. Free Wheelchair Mission GEN 1 Teardown, Remove Seat Cushion: 3 단계, 이미지 1/1
    • Untie the four ties around the corners and back of the chair by pulling the strings.
    • Remove the cushion from the chair.
  4. Free Wheelchair Mission GEN 1 Teardown, Remove Brakes: 4 단계, 이미지 1/1
    • Use the 10 mm box wrench to unscrew the two screws that hold the brake to the frame.
    • Remove the brake from the frame.
  5. Free Wheelchair Mission GEN 1 Teardown, Remove Wheel: 5 단계, 이미지 1/1
    • Use a 19 mm socket wrench to unscrew the axle bolt.
    • The Free Wheelchair Mission Multi-Purpose Tool can be used in place of the 19 mm socket wrench
    • Use a 19 mm adjustable wrench (also known as a Crescent wrench) to prevent the nut from spinning.
    • Slide the wheel off the frame.
  6. Free Wheelchair Mission GEN 1 Teardown, Remove Axle Plates: 6 단계, 이미지 1/3 Free Wheelchair Mission GEN 1 Teardown, Remove Axle Plates: 6 단계, 이미지 2/3 Free Wheelchair Mission GEN 1 Teardown, Remove Axle Plates: 6 단계, 이미지 3/3
    • Turn the chair around to see the two base plates that hold the axle to the back of the chair. There are two screws on each of the plates that connect the chair to the axle.
    • Hold the nut with a 10 mm wrench in one hand. In the other hand, use a wrench to remove the screw.
  7. Free Wheelchair Mission GEN 1 Teardown, Remove Front Frame and Castor Wheels: 7 단계, 이미지 1/2 Free Wheelchair Mission GEN 1 Teardown, Remove Front Frame and Castor Wheels: 7 단계, 이미지 2/2
    • Next you'll remove the screws that hold the back frame, chair, castor wheel, and front frame together. There is one screw on each side of the chair immediately above where the brakes are located.
    • Remove both of these screws using a 10 mm wrench.
    • Separate the front frame and and the castor wheel from the chair.
  8. Free Wheelchair Mission GEN 1 Teardown, Remove Chair: 8 단계, 이미지 1/1
    • Remove the chair from the frame.
Mike Sevilla
회원 가입일: 04/05/13
348 평판
안내서 3개 작성하였습니다
Cal Poly, Team 14-7, Maness Spring 2013 Cal Poly, Team 14-7, Maness Spring 2013 회원
CPSU-MANESS-S13S14G7
5 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,534
