주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. GEN 2 Wheelchair 수리는 저희 서비스 설명서를 사용하십시오.
  1. GEN 2 Wheelchair Teardown, GEN 2 Wheelchair Teardown: 1 단계, 이미지 1/3 GEN 2 Wheelchair Teardown, GEN 2 Wheelchair Teardown: 1 단계, 이미지 2/3 GEN 2 Wheelchair Teardown, GEN 2 Wheelchair Teardown: 1 단계, 이미지 3/3
    • Find a clean area to work in so every part can be accounted for.
  2. GEN 2 Wheelchair Teardown: 2 단계, 이미지 1/3 GEN 2 Wheelchair Teardown: 2 단계, 이미지 2/3 GEN 2 Wheelchair Teardown: 2 단계, 이미지 3/3
    • Remove the footrest by unscrewing the lower bolt, using the 10 mm wrench.
    • Remove the upper bolt above the socket.
    • Slide out the footrest and unscrew the plate welded to the socket.
    • Slide the plate upward and off of the track to remove.
    • Untie the foot retention belt.
  3. GEN 2 Wheelchair Teardown: 3 단계, 이미지 1/2 GEN 2 Wheelchair Teardown: 3 단계, 이미지 2/2
    • Undo the seatbelt.
    • Remove the seat cushion by pulling it off of the velcro.
    • Remove the back padding by untieing the straps attached to the back pad.
  4. GEN 2 Wheelchair Teardown: 4 단계, 이미지 1/1
    • Turn the wheelchair upside down and untie the plastic seat.
    • Remove the plastic seat support.
  5. GEN 2 Wheelchair Teardown: 5 단계, 이미지 1/1
    • Locate the plastic cap on top of the caster wheels.
    • Place the 10mm wrench underneath the plastic cap and lift it up to remove.
  6. GEN 2 Wheelchair Teardown: 6 단계, 이미지 1/2 GEN 2 Wheelchair Teardown: 6 단계, 이미지 2/2
    • Remove the caster wheels by unscrewing the bolt under the cap with a 19 mm wrench.
    • Lift the wheelchair up to pull the caster wheels off.
    • Use caution: The metal sheath and the bearing of the caster wheel is not attached and may fall off upon removal.
  7. GEN 2 Wheelchair Teardown: 7 단계, 이미지 1/1
    • Use a 1/2 inch socket wrench to unscrew bolts to remove the brakes.
    • Pull the brakes off.
  8. GEN 2 Wheelchair Teardown: 8 단계, 이미지 1/2 GEN 2 Wheelchair Teardown: 8 단계, 이미지 2/2
    • Remove the wheels by placing a 19 mm socket wrench on the inside of the wheel and unscrew the bolt.
    • Unscrew the bolt on the outside of the wheel by using a 19 mm socket wrench.
  9. GEN 2 Wheelchair Teardown: 9 단계, 이미지 1/3 GEN 2 Wheelchair Teardown: 9 단계, 이미지 2/3 GEN 2 Wheelchair Teardown: 9 단계, 이미지 3/3
    • Unscrew all of the 10mm bolts on the frame using the 10 mm wrench (15 bolts total).
    • Separate the handle frame pieces from the metal side structure (2 bolts total).
    • Remove the bolts attaching the three support beams (4 bolts each, 12 bolts total).
  10. GEN 2 Wheelchair Teardown: 10 단계, 이미지 1/1
    • Remove the bolt with the rubber cap that attaches the air pump to the center support on the bottom.
  11. GEN 2 Wheelchair Teardown: 11 단계, 이미지 1/1
    • Congratulations! Your teardown is now complete. Make sure all of the parts are accounted for before storing or shipping.
Jennifer
회원 가입일: 04/17/13
32 평판
안내서 1개 작성함
Cal Poly, Team 14-8, Maness Spring 2013 Cal Poly, Team 14-8, Maness Spring 2013 회원
CPSU-MANESS-S13S14G8
5 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 17
전체 시간: 2,301
