주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Galaxy S23 수리는 저희 서비스 설명서를 사용하십시오.
  1. Galaxy S23 Teardown, Remove the rear glass: 1 단계, 이미지 1/2 Galaxy S23 Teardown, Remove the rear glass: 1 단계, 이미지 2/2
    • First we heat the rear glass of the phone to melt all the adhesive that glues the glass to the rest of the phone. We can do it either with an iOpener or with a heat gun.
    • Now with a flat object or with an opening pick we cut the remaining adhesive by inserting it between the glass and the rest of the phone and passing it along the entire edge.
    • Now we can raise the back panel and we're done.
  2. Galaxy S23 Teardown, Remove the Wireless Coil and NFC Antenna: 2 단계, 이미지 1/1
    • Unscrew the 6 Phillips #00 screws that weld the wireless charging base and the NFC antenna.
    • Disconnect the connector connecting the two antennas and remove everything.
  3. Galaxy S23 Teardown, Disconnect the Battery: 3 단계, 이미지 1/1
    • Unplug the connector to disconnect the battery.
  4. Galaxy S23 Teardown, Unscrew the Charging Board: 4 단계, 이미지 1/1
    • Remove the 7 #00 Phillips screws that secure the charging board to the rest of the phone.
  5. Galaxy S23 Teardown, Remove the SIM: 5 단계, 이미지 1/1
    • Use a fine tool to pull out the SIM tray.
  6. Galaxy S23 Teardown, Remove the connectors: 6 단계, 이미지 1/1
    • Remove the connector with your fingers or a flat tool.
  7. Galaxy S23 Teardown, Remove the Front Camera Protector: 7 단계, 이미지 1/1
    • Unscrew the 5 Phillips #00 screws that secure the front camera protector to the rest of the phone.
  8. Galaxy S23 Teardown, Remove the Front Camera: 8 단계, 이미지 1/1
    • Unplug the front camera connector and remove it.
  9. Galaxy S23 Teardown, Remove the Rear Cameras: 9 단계, 이미지 1/2 Galaxy S23 Teardown, Remove the Rear Cameras: 9 단계, 이미지 2/2
    • Remove the two Phillips #00 screws that secure the rear camera protector to the rest of the phone.
    • Unplug the three connectors of the three rear cameras and remove them.
  10. Galaxy S23 Teardown, Remove the Charging Board: 10 단계, 이미지 1/1
    • Unscrew the three Phillips #00 screws that secure the docking board to the rest of the phone and then remove it.
  11. Galaxy S23 Teardown, Remove the battery: 11 단계, 이미지 1/3 Galaxy S23 Teardown, Remove the battery: 11 단계, 이미지 2/3 Galaxy S23 Teardown, Remove the battery: 11 단계, 이미지 3/3
    • With the special tab, detach it and pull to facilitate the removal of the battery.
  12. Galaxy S23 Teardown, Remove add-ons: 12 단계, 이미지 1/2 Galaxy S23 Teardown, Remove add-ons: 12 단계, 이미지 2/2
    • Remove the volume keys motherboard and them too.
  13. Galaxy S23 Teardown, Finished: 13 단계, 이미지 1/1
    • We have completely disassembled the new Samsung Galaxy S23.
Andrea Alfani
회원 가입일: 04/20/22
7,697 평판
안내서 5개 작성하였습니다
Kid fixers Kid fixers 회원
Community
162 회원들
안내서 300개 작성하였습니다
댓글 8개
You beat iFixit to the punch! Nice work. They're really falling behind. Good thing we have awesome users like yourself! Thank you!
Damien Lobb - 답글
Thank You so much i really appreciate it thank you so much i really appreciate it
Andrea Alfani -
Will the microphone get damage if I wrongly insert the sim pin into it?
apple terr - 답글
Mine did not damaged, all works properly)
Ramil Salakhetdinov -
댓글 쓰기
조회 통계:
24 시간 전: 76
7일 전: 368
30일 전: 1,651
전체 시간: 28,645
