주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Camera 수리는 저희 서비스 설명서를 사용하십시오.
  1. GooGo Teardown, GooGo Teardown: 1 단계, 이미지 1/2 GooGo Teardown, GooGo Teardown: 1 단계, 이미지 2/2
    • Opening the device by simply separating the two halves with a plastic prying tool.
첨부 문서
jerome cintas
회원 가입일: 09/20/13
179 평판
안내서 1개 작성함
댓글 7개
I cant see where the camera is, is it a lense focusing onto a ccd on the motherboard???
Steve Rock - 답글
Hi Jerome,
There is a small brass thread on the side of the Googo Camera,
Do you know what it is for.
many Thanks Dave Gould dave.gould@ymail.com
David Gould - 답글
hi .. if there a place to solder in a more powerful antenna, would that even help?
sadstory - 답글
Do you know how to reset the password of the camera by hardware?
Hugo Uchida Frausto - 답글
My phone is showing error in camera can't be opened
Sib Gat - 답글
sorry guys for some reason i never saw your comments before now...
the camera is located behind the bottom adhesive in the picture. it is a separated pcb.
i have no idea what the brass thread is for..
for the password, no idea how to reset it, i must admit i haven't touched the camera for a while...
sib gat, sorry i have no idea what the problem might be. check that you are on the googo's wifi network, and that settings for the wifi are ok.
Again, sorry i just received sib gat's comment notification, i don't remember seeing any other notification..
Jerome
jerome cintas - 답글
Man i’m wanting to purchase a googo cam but all the feedback I find seem to be negative. not one positive. Are all these cameras ,hmm, not very good or is it just the good ones haven’t left any feedback. Really wanted on of these but having second thoughts now
Eric K - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 24
전체 시간: 8,076
