필요한 것
Begin with your standard issue Nest Mini. note the white insert inside the mounting hole.
Insert an appropriate tool underneath this flexible rubber white insert. I'm using a knife. Knives are sharp, be careful.
The rubber insert comes out, revealing a sneaky T6 Torx screw.
Do the normal thing with the T6 Torx screw.
Grab the front of the speaker in one hand and the back cover in the other, and rotate the back clockwise slightly. It should rotate just a few millimeters.
Four lugs inside are disengaged when it rotates. You can now gently lift the back cover away. Be careful not to put strain on the ribbon cable.
Using a plastic spudger, unfasten the zero insertion force (ZIF) connector latch. Slide the ribbon connector out of the ZIF connector to free it.
Three more T6s secure a board bringing power input and a microphone switch down the ribbon cable.
Four more T6 screws secure the speaker assembly to the front.
A small connector must be unplugged to detach the speaker after unscrewing. Under the speaker, we find ... more T6 screws!
The speaker has no fasteners and probably cannot be opened further nondestructively.
The foam covering the speaker hides a serial number in QR and written form.
So far all the T6 screws have been the same. The five screws securing this piece, which covers the logic board, are not. Four long ones and a short one. If you forget the positions, the picture has your back.
Relieved of its T6s, the last piece pulls away with a bit of thermal shmoo.
Here lies the smarts of this speaker. Ain't that much to look at, is it?
The board can be gently prised from its casing, now secured only by some glue, thermal pads, and foil tape.
There's not much in here that's serviceable without an advanced degree in fiddly soldering.
댓글 24개
Hello notethan, good teardown, is some marking readable on the flash and cpu chips?
Thanks Leonid.
The NAND flash is TC58NVG2S0H
The SoC is Synaptics AS-370 A1
RAM is NT5CC128M16JR
The entire markings on each chip are:
1932KLE
ZN4238 CHINA
TC58NVG2S0H
8AI6
Synaptics
AS-370 A1
933AFFH 423
U15014.000F
NT5CC128M16JR-EK[there's more letters but they're covered]
92420800EP L T[there's more letters but they're covered]
Hello. The power brick gives out 14V 1.1A. You can buy USB-C Power Delivery module and program it to give out 15v (ranges from 14 - 16v, depending on your power supply). My highly guess is that the logic inside has it own downconverter to its desired voltage, but the driver for the speaker takes whatever comes in directly, and my guess they can handle a wide range of voltage.
@hk_asking The switch is on a small peripheral board connected by a ribbon cable. I cannot tell if it directly disconnects the microphone.
