주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Griffin FireWave 수리는 저희 서비스 설명서를 사용하십시오.
  1. Griffin FireWave Teardown, Griffin FireWave Teardown: 1 단계, 이미지 1/1
    • The Fire Wave case snaps together, which means its a pain to take apart without damaging the cosmetic appearance.
    • 8
  2. Griffin FireWave Teardown: 2 단계, 이미지 1/1
    • The best place to start is the right side, where the fire wire ports are located.
  3. Griffin FireWave Teardown: 3 단계, 이미지 1/1
    • Once I got it started it was pretty easy form there, using the plastic spudger.
  4. Griffin FireWave Teardown: 4 단계, 이미지 1/1
    • Ok now that its open lets have a look inside.
    • The board is pretty simplistic, no heat-sinks or fans of the sort.
  5. Griffin FireWave Teardown: 5 단계, 이미지 1/1
    • Here we have the Micronas MAS 3529H Dolby Digital and Mpeg2 Layer 2 Audio Decoder. Its the heart of the sound card, without it, there would be no 5.1. Dolby labs made a contract with Micronas to manufacture these chips under specifications.
    • 6
    • The MAS 3529H decoder IC acts as a complete implementation of 5.1 DTS and Dolby Digital/Pro Logic II decoders. On the chip’s 8-channel output an Lt/Rt or Lo/Ro downmix is available simultaneously to the multi-channel audio for recording or headphone usage.
    • I
  6. Griffin FireWave Teardown: 6 단계, 이미지 1/1
    • The second chip is the Wolfson Microelectronics WM8766G. This semiconductor is a 24-bit 192kHz 6-channel DAC used in many home theater devices such as receivers and dvd/blu-ray players.
    • The chip right below it is the Xilinx XC9536XL High Perfonmace CPLD (Complex Programmable Logic Device). It works with the Wolfson chip to calculate delay time of the center and surround speakers.
  7. Griffin FireWave Teardown: 7 단계, 이미지 1/1
    • The front of the device has two lights that indicate power and if the dolby chip is active or not.
    • Thats about it for this teardown. I still use my firewave today, it works great for watching DVD's and such.
WiseGeek
회원 가입일: 04/04/11
1,364 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 4,723
