소개
I teach you how to open the laptop to access and change the RAM, hard drive or whatever you need.
동영상 개요
Put the laptop facing down
Move the left battery safe lock to the right
Slide the right battery safe lock to the left
This lock is harder than the previous, with this the battery should pop-up.
Use a straw to take off just enough of the rubber feet of the 4 corners
Use a Phillips screwdriver 0
Replace each rubber foot in place after removing the screws
You will have a total of 10 screws
It will go out easily with or without a straw
You can check the model number
Flip the laptop and open it
Use a plastic tool or a straw to separate the pieces of the chassis
Flip the laptop and separate the inferior cover of the chassis
Hard Drive 2.5" SATA
2 RAM memory slots type DDR4 SO-DIMM
CPU Intel 7th generation
Active heat sink (fan)
Wireless card
Watch battery, 3V. CR2030
다른 39명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 16개
Se me rompio las bisagras … como se reemplazan ?
No tengo la laptop a mano para tomarle fotos, aunque en el paso 7 se puede ver algo. Depende de la rotura, lo típico que se rompe es la rosca para los tornillos, hay que crear un nueva rosca con material adicional, sin embargo, desconozco el procedimiento. En todo caso, puedes contactarme a mis RRSS que están en mi perfil de ifixit.
Your step by step guide is apt. Thanks
Perebowei Titus Otoru Nigeria
Saludos, ya entregué la laptop al cliente.
