주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. HP G61 수리는 저희 서비스 설명서를 사용하십시오.
  1. HP G61-430SB Teardown, HP G61-430SB Teardown: 1 단계, 이미지 1/1
    • Turn the device over and remove the screws from the battery. Remove the black panels holding the HDD, ram, and wifi.
  2. HP G61-430SB Teardown: 2 단계, 이미지 1/3 HP G61-430SB Teardown: 2 단계, 이미지 2/3 HP G61-430SB Teardown: 2 단계, 이미지 3/3
    • Remove the RAM modules and the HDD as shown in the pictures.
  3. HP G61-430SB Teardown: 3 단계, 이미지 1/2 HP G61-430SB Teardown: 3 단계, 이미지 2/2
    • Locate the screw for the DVD player and remove it. Then remove the DVD player with a thin spudger.
  4. HP G61-430SB Teardown: 4 단계, 이미지 1/2 HP G61-430SB Teardown: 4 단계, 이미지 2/2
    • Remove the screws to remove the keyboard.
  5. HP G61-430SB Teardown: 5 단계, 이미지 1/2 HP G61-430SB Teardown: 5 단계, 이미지 2/2
    • Remove the screws that are circled in the picture. These screws hold the case of the laptop.
  6. HP G61-430SB Teardown: 6 단계, 이미지 1/1
    • Remove the WIFI antenna cables from WIFI card.
    • Then remove the screws of the WIFI card and remove the card.
  7. HP G61-430SB Teardown: 7 단계, 이미지 1/2 HP G61-430SB Teardown: 7 단계, 이미지 2/2
    • Flip the laptop around and gently remove the keyboard with your fingers.
    • Start with the corners of the keyboard.
    • Gently loosen the keyboard with a flat head screwdriver or a thin spudger.
  8. HP G61-430SB Teardown: 8 단계, 이미지 1/2 HP G61-430SB Teardown: 8 단계, 이미지 2/2
    • After removing the keyboard, find the other screws located in the grey panel.
    • Remove the black plastic. Be careful with the white flat cable.
  9. HP G61-430SB Teardown: 9 단계, 이미지 1/1
    • Remove the black flat wire of the LCD screen from the motherboard.
  10. HP G61-430SB Teardown: 10 단계, 이미지 1/1
    • Remove the hinge screws with the screwdriver from the left side to the right side.
    • Under one of the two hinges, there is a hidden screw (case)
  11. HP G61-430SB Teardown: 11 단계, 이미지 1/2 HP G61-430SB Teardown: 11 단계, 이미지 2/2
    • Remove the audio boxes.
    • Remove all the other wires and cables.
    • Then gently separate the screen from the case.
  12. HP G61-430SB Teardown: 12 단계, 이미지 1/2 HP G61-430SB Teardown: 12 단계, 이미지 2/2
    • Use an iOpener to separate the grey case from the bottom case.
    • Careful: the battery compartment is together with the grey panel.
    • Tip: "slide" the iOpener while opening until you hear clicks. It is easy if you slide.
  13. HP G61-430SB Teardown: 13 단계, 이미지 1/3 HP G61-430SB Teardown: 13 단계, 이미지 2/3 HP G61-430SB Teardown: 13 단계, 이미지 3/3
    • Remove the motherboard by removing the screws first. Be careful with the cables and the wires.
    • Be careful with the connector of the DC power jack. You can replace the USB drivers on that side as well.
  14. HP G61-430SB Teardown: 14 단계, 이미지 1/3 HP G61-430SB Teardown: 14 단계, 이미지 2/3 HP G61-430SB Teardown: 14 단계, 이미지 3/3
    • Remove the cooler.
  15. HP G61-430SB Teardown: 15 단계, 이미지 1/1
    • To remove the Processor, unlock the processor socket with a flat screwdriver.
    • Then gently remove the Processor.
Kevin D
회원 가입일: 05/02/14
7,276 평판
안내서 21개 작성하였습니다
댓글 2개
Thanks a bunch this helped a whole lot!!!!
Teresa halley - 답글
Thank you very much. Very well explained :)
a.thorne.987 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 19
전체 시간: 8,899
