주요 콘텐츠로 건너뛰기
해당 분해도에 사용된 도구
소개
I just went along, tearing it apart. Pictures are of what I found, along with some of the tools I used.
해당 분해도는 수리 안내서가 아닙니다. HP OfficeJet Pro 8000 수리는 저희 서비스 설명서를 사용하십시오.
  1. Removing tray and such. Removing tray and such. Removing tray and such.
    • Removing tray and such.
  2. Taking off the top. Taking off the top. Taking off the top.
    • Taking off the top.
  3. Print heads coming out. Print heads coming out. Print heads coming out.
    • Print heads coming out.
  4. Ink coming out. Ink coming out. Ink coming out.
    • Ink coming out.
  5. T10 bit; time to start unscrewing. T10 bit; time to start unscrewing. T10 bit; time to start unscrewing.
    • T10 bit; time to start unscrewing.
  6. Finding screws. Finding screws. Finding screws.
    • Finding screws.
  7. Finding more screws. Finding more screws. Finding more screws.
    • Finding more screws.
  8. Finding hidden screws. Finding hidden screws. Finding hidden screws.
    • Finding hidden screws.
  9. Finding more hidden screws; breaking off side-panel cover thingy. Finding more hidden screws; breaking off side-panel cover thingy. Finding more hidden screws; breaking off side-panel cover thingy.
    • Finding more hidden screws; breaking off side-panel cover thingy.
  10. The motherboard. The motherboard. The motherboard.
    • The motherboard.
  11. Finding more release mechanisms. Finding more release mechanisms. Finding more release mechanisms.
    • Finding more release mechanisms.
  12. Off come more outer panels; some with more (brute) force than others. Off come more outer panels; some with more (brute) force than others. Off come more outer panels; some with more (brute) force than others.
    • Off come more outer panels; some with more (brute) force than others.
  13. Miscellaneous parts. Miscellaneous parts. Miscellaneous parts.
    • Miscellaneous parts.
  14. More parts/stuff coming out. More parts/stuff coming out. More parts/stuff coming out.
    • More parts/stuff coming out.
  15. Getting deeper! Getting deeper! Getting deeper!
    • Getting deeper!
  16. Various assemblies coming apart/out. Various assemblies coming apart/out. Various assemblies coming apart/out.
    • Various assemblies coming apart/out.
  17. Found some T8 screws used for a controller board and the motor screws. Found some T8 screws used for a controller board and the motor screws. Found some T8 screws used for a controller board and the motor screws.
    • Found some T8 screws used for a controller board and the motor screws.
  18. Motor out, and plastic guide slide thingy detached from one end. Motor out, and plastic guide slide thingy detached from one end. Motor out, and plastic guide slide thingy detached from one end.
    • Motor out, and plastic guide slide thingy detached from one end.
  19. Print head assembly/hoses coming out/apart. Print head assembly/hoses coming out/apart. Print head assembly/hoses coming out/apart.
    • Print head assembly/hoses coming out/apart.
  20. More print head stuff. More print head stuff. More print head stuff.
    • More print head stuff.
  21. More miscellaneous assemblies. More miscellaneous assemblies. More miscellaneous assemblies.
    • More miscellaneous assemblies.
  22. Another group of circuitry. Another group of circuitry. Another group of circuitry.
    • Another group of circuitry.
  23. More mechanical parts. More mechanical parts. More mechanical parts.
    • More mechanical parts.
  24. More assemblies, and a pile of junk... More assemblies, and a pile of junk... More assemblies, and a pile of junk...
    • More assemblies, and a pile of junk...
  25. Leaked magenta, and as far as I went before calling the job "done enough". Leaked magenta, and as far as I went before calling the job "done enough". Leaked magenta, and as far as I went before calling the job "done enough".
    • Leaked magenta, and as far as I went before calling the job "done enough".
cf8geek
회원 가입일: 2014년 03월 03일
181 평판
안내서 1개 작성함
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 18
전체 시간: 7,196
