주요 콘텐츠로 건너뛰기
소개
This teardown illustrates how to deconstruct the HP MR Headset (DE). This teardown also identifies some of the components within the HMD, and is open to any edits or suggestions for unidentified elements.
해당 분해도는 수리 안내서가 아닙니다. HP Windows Mixed Reality Headset Developer Edition 수리는 저희 서비스 설명서를 사용하십시오.
  1. HMD Specs: Two high-resolution liquid crystal displays at 1440 x 1440
    • HMD Specs:
    • Two high-resolution liquid crystal displays at 1440 x 1440
    • 2.89” diagonal display size (x2)
    • Front hinged display
    • Double padded headband and adjustment knob
    • Built-in audio out and microphone support through 3.5mm jack
    • Single 4.00m/0.60m removable cable with HDMI 2.0 (display) and USB 3.0 (data) for connectivity
  2. Remove the foam protector from the velcro-type adhesive strip. Remove the two eye-rings with a flat head screwdriver. Also with a flat head screwdriver, carefully pry apart the outer plastic shell from the HMD
    • Remove the foam protector from the velcro-type adhesive strip.
    • Remove the two eye-rings with a flat head screwdriver.
    • Also with a flat head screwdriver, carefully pry apart the outer plastic shell from the HMD
  3. To remove the next layer of protective plastic, you'll need to remove 16 screws 1 on each side and 14 on the front
    • To remove the next layer of protective plastic, you'll need to remove 16 screws
    • 1 on each side
    • and 14 on the front
  4. Now that the screws are removed, the next plastic layer can be removed. The cable will still be connected to the adjustable head strap. This can be removed easily by prying it off with a flathead screwdriver
    • Now that the screws are removed, the next plastic layer can be removed.
    • The cable will still be connected to the adjustable head strap. This can be removed easily by prying it off with a flathead screwdriver
  5. Skip the upgrade.
    Take $10 off $50 with
    SKIPANDSAVE10
    Save Now
    Skip the upgrade.
    SKIPANDSAVE10
    Save Now
  6. In the bottom left corner of the HMD, you'll find the audio jack and the board attached to it. With a flat head screwdriver, gently pry the connector from the headphone jack board. Once the board has been disconnected, it will fall right out. With a flat head screwdriver, gently pry the connector from the headphone jack board. Once the board has been disconnected, it will fall right out.
    • In the bottom left corner of the HMD, you'll find the audio jack and the board attached to it.
    • With a flat head screwdriver, gently pry the connector from the headphone jack board. Once the board has been disconnected, it will fall right out.
  7. Remove four more screws. The bottom left screw will release the audio board support. Peel back the lenses at a 45° angle from the bottom up. You'll then see two yellow strips held with black protective tape. Peel back the tape with tweezers.
    • Remove four more screws. The bottom left screw will release the audio board support.
    • Peel back the lenses at a 45° angle from the bottom up.
    • You'll then see two yellow strips held with black protective tape. Peel back the tape with tweezers.
    • Also with tweezers, remove the yellow tape over the connection between the PCB and the lenses.
    • The lenses appear to be fresnel on the inside but smooth on the outside.
  8. With the lenses removed, you can begin separating the PCB from whats left of the HMD. USE TWEEZERS to peel back the two pieces of metallic tape on the PCB (this tape is SHARP — do not use your hands). Remove the four screws to remove the two metal clips on each side of the PCB.
    • With the lenses removed, you can begin separating the PCB from whats left of the HMD.
    • USE TWEEZERS to peel back the two pieces of metallic tape on the PCB (this tape is SHARP — do not use your hands).
    • Remove the four screws to remove the two metal clips on each side of the PCB.
  9. After removed the PCB, you can see the front camera sensor compartment. Peel off the copper tape on both side before the next step. (SHARP EDGES -TWEEZERS recommend). Remove 4 screws to disassemble the front camera sensor on each side.
    • After removed the PCB, you can see the front camera sensor compartment.
    • Peel off the copper tape on both side before the next step. (SHARP EDGES -TWEEZERS recommend).
    • Remove 4 screws to disassemble the front camera sensor on each side.
    • Cameras were not easily identifiable, however, they looked identical to the cameras we found in our Acer MR HMD teardown. Also had similar part numbers to the the Microsoft Surface 3 rear camera.
  10. The metal cover to the PCB can be easily pried apart with a flat head screwdriver. After doing this, the two screws connecting the cable to the PCB is revealed. Remove the two screws, then pop off the connector straight up, not at an angle.
    • The metal cover to the PCB can be easily pried apart with a flat head screwdriver.
    • After doing this, the two screws connecting the cable to the PCB is revealed.
    • Remove the two screws, then pop off the connector straight up, not at an angle.
  11. Cypress CYUSB3064-BZXC SuperSpeed USB Bridge Controller Cypress CYUSB3304-68LTXI HX3 USB 3.0 Hub
  12. The main cable is a USB and HDMI to a proprietary connector. Instead of plugging directly into the HMD, the proprietary connector plugs into a receptacle which is attached to an embedded connector (shown on the PCB in steps nine and ten). Instead of plugging directly into the HMD, the proprietary connector plugs into a receptacle which is attached to an embedded connector (shown on the PCB in steps nine and ten).
    • The main cable is a USB and HDMI to a proprietary connector.
    • Instead of plugging directly into the HMD, the proprietary connector plugs into a receptacle which is attached to an embedded connector (shown on the PCB in steps nine and ten).
  13. After finding an active cable module within the Acer headset, we were curious as to why the HP headset had no chips on their cable. So we opened up the proprietary connector on the cable (Do not do this. You won't be able to easily put it back together) Under the plastic shell, we found a similar Spectra7 cable module similar to that of the Acer Windows HMD Spectra7 VR8050 USB 3.0 Cable Equalizer
    • After finding an active cable module within the Acer headset, we were curious as to why the HP headset had no chips on their cable. So we opened up the proprietary connector on the cable (Do not do this. You won't be able to easily put it back together)
    • Under the plastic shell, we found a similar Spectra7 cable module similar to that of the Acer Windows HMD
    • Spectra7 VR8050 USB 3.0 Cable Equalizer
    • Spectra7 HT8181 HDMI 2.0 Cable Equalizer
Super_All_In_One
회원 가입일: 2017년 08월 23일
201 평판
안내서 2개 작성하였습니다
This is fantastic thank you! Any plans on tearing down the other four MR headsets from Microsoft?
Connor Dolan - 답글
Hi there,
I am wondering if anyone knows the components I have highlighted.
[IMG]http://i63.tinypic.com/2hxsz1f.jpg[/IMG]
[IMG]http://i66.tinypic.com/2mm5zyu.jpg[/IMG]
[IMG]http://i63.tinypic.com/33w8hop.jpg[/IMG]
My HP WMR unit had a power surge and has burnt out most of these components.
A good electrical engineer friend of mine has cast a close eye over all the other components on the board, showing no physical damage (which I know doesn’t mean that they all ok).
I live in hope that I will be able to repair my WMR headset, as I have myself had plenty of experience with SM components.
Just identifying the values of these components is proving to be mighty tricky!
I believe (A) 6 pin “EDVGA” are voltage regulators - SOT23-6?
(B) Transistor? - “NA ID9” ?
Appreciate any help :)
Paul
Paul Slater - 답글
Any info on the sensor in the center mounted between the lenses?
Frank McCown - 답글
From what i’ve seen on other headsets it’s a light sensor ..
controls brightness during light bleed.
Timothy Bartlett - 답글
Hi. My cameras stopped working, and I think it's because of the USB cable damage.
Do usb3. 0 sstx ssrx lines conduct current when there's no power on hdmi & USB equalizers? I'm sticking one probe of the multimeter to the USB's sstx and the other one to every pin of the combined HDMI-USB plug.
USB 2.0's lines conduct current just fine, but usb 3's line are quiet.
Thanks.
PainSandwich - 답글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 50
지난 30일: 311
전체 시간: 6,470
