주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. HTC Droid Incredible 수리는 저희 서비스 설명서를 사용하십시오.
  1. HTC Droid Incredible Teardown, Opening it up: 1 단계, 이미지 1/1
    • Start by removing the back cover.
  2. HTC Droid Incredible Teardown, Removing Battery: 2 단계, 이미지 1/1
    • Then remove the battery.
  3. HTC Droid Incredible Teardown, Unscrewing Back: 3 단계, 이미지 1/1
    • Then remove the four screws located in each corner of the phone.
  4. HTC Droid Incredible Teardown, Removing Back: 4 단계, 이미지 1/1
    • Then carefully start to spit the phone from any corner.
  5. HTC Droid Incredible Teardown, Unscrewing Motherboard: 5 단계, 이미지 1/3 HTC Droid Incredible Teardown, Unscrewing Motherboard: 5 단계, 이미지 2/3 HTC Droid Incredible Teardown, Unscrewing Motherboard: 5 단계, 이미지 3/3
    • Then remove the three screws. one at the top and the other two at the bottom.
  6. HTC Droid Incredible Teardown, Removing Strips and Motherboard: 6 단계, 이미지 1/3 HTC Droid Incredible Teardown, Removing Strips and Motherboard: 6 단계, 이미지 2/3 HTC Droid Incredible Teardown, Removing Strips and Motherboard: 6 단계, 이미지 3/3
    • After removing the screw you also have to remove the orange strip by lifting up the top of the container. Then pull the strip out of it.
  7. HTC Droid Incredible Teardown, Removing Screen: 7 단계, 이미지 1/3 HTC Droid Incredible Teardown, Removing Screen: 7 단계, 이미지 2/3 HTC Droid Incredible Teardown, Removing Screen: 7 단계, 이미지 3/3
    • Remove the top two screws on the pone that will be encased in tape, and then pull the screen out using Blue Opening tool or other.
  8. HTC Droid Incredible Teardown, Screen Is Removed: 8 단계, 이미지 1/2 HTC Droid Incredible Teardown, Screen Is Removed: 8 단계, 이미지 2/2
    • That is how you take apart the HTC
Brayan Rocha
회원 가입일: 05/28/15
100 평판
안내서 1개 작성함
CCNTH Repair Project CCNTH Repair Project 회원
Community
2 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 1,455
