주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. HTC Evo 3D 수리는 저희 서비스 설명서를 사용하십시오.
  1. HTC Evo 3D Teardown, HTC Evo 3D Teardown: 1 단계, 이미지 1/1
    • First things first, Remove the back cover, battery and SD card.
  2. HTC Evo 3D Teardown: 2 단계, 이미지 1/1
    • Remove the four T5 Torx screws.
    • Then remove the two Phillips screws.
    • *Very sorry for dark image*
  3. HTC Evo 3D Teardown: 3 단계, 이미지 1/1
    • Once the screws are all out from the exterior back case, Begin separating the front housing from the back by using a spudger or any similar tool.
    • Begin from the bottom were the battery bay is, It is the easiest way.
    • Be careful of ribbons behind the plastic
  4. HTC Evo 3D Teardown: 4 단계, 이미지 1/3 HTC Evo 3D Teardown: 4 단계, 이미지 2/3 HTC Evo 3D Teardown: 4 단계, 이미지 3/3
    • Once separated begin to remove the LED board. Apply only light upward force and it will detach itself.
  5. HTC Evo 3D Teardown: 5 단계, 이미지 1/2 HTC Evo 3D Teardown: 5 단계, 이미지 2/2
    • Vibrator come's out easy, Just grab it by the wire and give it a little tug and it should come out.
    • Start unlocking the clips holding the ribbons. pull the white tab up to unlock.
    • Example: bottom left is unlocked, bottom right is locked. upper left has bin finished and removed.
    • Tuck the ribbons in without bending or making tears in them.
  6. HTC Evo 3D Teardown: 6 단계, 이미지 1/1
    • Behind the main board is two more ribbon's.
    • Flip both tab locks holding the ribbons and they will slide out vary easily, Don't force it.
    • Wifi/cellular antena port, Lift up cord head directly to remove and press straight down centered to put back on.
    • As a side note, the grey tape on the back side of the board was covering the clips so i cut a small section for this guide.
  7. HTC Evo 3D Teardown: 7 단계, 이미지 1/1
    • This concludes the (simple) teardown of the Evo 3D.
David
회원 가입일: 03/18/12
9,626 평판
안내서 2개 작성하였습니다
Master Techs Master Techs 회원
Community
311 회원들
안내서 1,196개 작성하였습니다
댓글 한 개
Thanks. This was very helpful.
dano706 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 14
전체 시간: 19,304
