주요 콘텐츠로 건너뛰기
해당 분해도에 사용된 도구
소개
This product teardown will require pliers, a Phillips head screwdriver, a Y-head screwdriver, and a flathead screwdriver. Certain components will require some prying, so be prepared. You will also need some grip paste available, as some screws are placed very tightly in their spots.
해당 분해도는 수리 안내서가 아닙니다. Home Essentials Sandwich Press 수리는 저희 서비스 설명서를 사용하십시오.
  1. Unscrew the 10mm screws securing the plastic handle cover using a size PH1 screwdriver. These screws are very loose and easy to remove.
    • Unscrew the 10mm screws securing the plastic handle cover using a size PH1 screwdriver.
    • These screws are very loose and easy to remove.
  2. Unscrew the metal hot plates from the plastic covering using a size PH1 screwdriver. The screws are 12 mm long. The screws are 12 mm long.
    • Unscrew the metal hot plates from the plastic covering using a size PH1 screwdriver.
    • The screws are 12 mm long.
  3. Unscrew the plastic handle cover using a Special Key Tri-wing. One screw was very hard to unscrew, so grip paste had to be used. The screws are 9 mm long.
    • Unscrew the plastic handle cover using a Special Key Tri-wing.
    • One screw was very hard to unscrew, so grip paste had to be used.
    • The screws are 9 mm long.
  4. Remove the plug-in cord caps using  a pair of pliers.
    • Remove the plug-in cord caps using a pair of pliers.
    • The metal caps have to be bent a bit to remove the plug-in cord caps, which means the metal caps will not work anymore.
  5. Now the metal plates are loose from the plastic cover. The plates need to be moved until the end of their hinge slots to slide them apart. The hinges are very easy to take apart, once it is loose from the plastic cover. The hinges are very easy to take apart, once it is loose from the plastic cover.
    • Now the metal plates are loose from the plastic cover. The plates need to be moved until the end of their hinge slots to slide them apart.
    • The hinges are very easy to take apart, once it is loose from the plastic cover.
  6. Separate the snap fit and remove the light covers. Remove the cords of the lights by pulling them out of their snap fit. Remove the light covers by pushing them out of the plastic cover.
    • Separate the snap fit and remove the light covers.
    • Remove the cords of the lights by pulling them out of their snap fit.
    • Remove the light covers by pushing them out of the plastic cover.
    • The lights are being taken out very easily with not much pressure.
  7. Remove the press latch by using a screwdriver; add some pressure to it to get the latch loose. Removing the press latch is hard and requires extra effort.
    • Remove the press latch by using a screwdriver; add some pressure to it to get the latch loose.
    • Removing the press latch is hard and requires extra effort.
  8. Unscrew the heating element covers using a size PH1 screwdriver. Remove the heating element covers from the plates. These screws are very loose and easy to remove
    • Unscrew the heating element covers using a size PH1 screwdriver.
    • Remove the heating element covers from the plates.
    • The screws are 5 mm long.
  9. Unscrew the heating element wires from the hot plates using a PH1 screwdriver. The screws are 5 mm long. Remove the heating elements using a Phillips head screwdriver, and put this screwdriver under the heating elements. Removing the heating elements requires some more pressure because they are put in with a tight snap fit. The heating element will also deform when removed.
    • Unscrew the heating element wires from the hot plates using a PH1 screwdriver. The screws are 5 mm long.
    • Remove the heating elements using a Phillips head screwdriver, and put this screwdriver under the heating elements.
    • Removing the heating elements requires some more pressure because they are put in with a tight snap fit. The heating element will also deform when removed.
Anna Stapor
회원 가입일: 2018년 03월 07일
169 평판
안내서 1개 작성함
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 355
