주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
In this guide, you will learn how to grab and embed an HTML code that allows you to publish an iFixit guide or teardown onto another site.
  1. Navigate to the teardown or guide page that you would like to embed.
    • Navigate to the teardown or guide page that you would like to embed.
  2. If you wish to embed the guide or teardown in a different language than the one currently selected: Click on the language icon in the upper right of the header bar. In the pop-up window, click to select the desired language.
    • If you wish to embed the guide or teardown in a different language than the one currently selected:
    • Click on the language icon in the upper right of the header bar.
    • In the pop-up window, click to select the desired language.
    • The site will load the page in the selected language.
  3. Click the "Options" button on the upper-righthand corner of the page. Select "Embed This Guide" from the dropdown menu.
    • Click the "Options" button on the upper-righthand corner of the page.
    • Select "Embed This Guide" from the dropdown menu.
  4. A pop-up window will appear with an HTML embed code and a preview of your embedded guide. Select the size you wish the embedded guide to be.
    • A pop-up window will appear with an HTML embed code and a preview of your embedded guide.
    • Select the size you wish the embedded guide to be.
    • Copy the auto-generated HTML code.
  5. Paste your HTML code into the site's text box. Enjoy your embedded guide!
    • Paste your HTML code into the site's text box.
    • Enjoy your embedded guide!
결승점
다른 6명이 해당 안내서를 완성하였습니다.
Julia
회원 가입일: 2012년 02월 09일
1,890 평판
안내서 1개 작성함
Fix blinking screen on startup
Richard Woolwine - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 36
전체 시간: 2,268
