소개
In this guide, you will learn how to grab and embed an HTML code that allows you to publish an iFixit guide or teardown onto another site.
Navigate to the teardown or guide page that you would like to embed.
If you wish to embed the guide or teardown in a different language than the one currently selected:
Click on the language icon in the upper right of the header bar.
In the pop-up window, click to select the desired language.
Click the "Options" button on the upper-righthand corner of the page.
Select "Embed This Guide" from the dropdown menu.
Select the size you wish the embedded guide to be.
Copy the auto-generated HTML code.
Paste your HTML code into the site's text box.
Enjoy your embedded guide!
다른 11명이 해당 안내서를 완성하였습니다.
댓글 3개
Fix blinking screen on startup
Is there an API to access contents?
Is this what you’re looking for: https://www.ifixit.com/api/2.0/doc/
