주요 콘텐츠로 건너뛰기
필요한 것
동영상 개요
해당 분해도는 수리 안내서가 아닙니다. Huawei P8 Lite 수리는 저희 서비스 설명서를 사용하십시오.
  1. Huawei P8 Lite Teardown, Huawei P8 Lite Teardown: 1 단계, 이미지 1/2 Huawei P8 Lite Teardown, Huawei P8 Lite Teardown: 1 단계, 이미지 2/2
    • Remove the SIM & SD card trays first.
  2. Huawei P8 Lite Teardown: 2 단계, 이미지 1/2 Huawei P8 Lite Teardown: 2 단계, 이미지 2/2
    • Remove the battery door—it's fastened tightly by clips. Free the clips with your fingernail or a pry tool.
    • Be careful because the midframe is easily scratched, and the glass at the top of the battery door is easily broken.
  3. Huawei P8 Lite Teardown: 3 단계, 이미지 1/2 Huawei P8 Lite Teardown: 3 단계, 이미지 2/2
    • Remove the torx screws on the back.
  4. Huawei P8 Lite Teardown: 4 단계, 이미지 1/2 Huawei P8 Lite Teardown: 4 단계, 이미지 2/2
    • Remove the loudspeaker by prying it up with a spudger.
  5. Huawei P8 Lite Teardown: 5 단계, 이미지 1/3 Huawei P8 Lite Teardown: 5 단계, 이미지 2/3 Huawei P8 Lite Teardown: 5 단계, 이미지 3/3
    • Remove the securing brackets covering the motherboard.
  6. Huawei P8 Lite Teardown: 6 단계, 이미지 1/3 Huawei P8 Lite Teardown: 6 단계, 이미지 2/3 Huawei P8 Lite Teardown: 6 단계, 이미지 3/3
    • Carefully release all the connectors on the board, and remove the motherboard.
  7. Huawei P8 Lite Teardown: 7 단계, 이미지 1/3 Huawei P8 Lite Teardown: 7 단계, 이미지 2/3 Huawei P8 Lite Teardown: 7 단계, 이미지 3/3
    • Remove the rear camera and front camera.
  8. Huawei P8 Lite Teardown: 8 단계, 이미지 1/1
    • Remove the power flex.
  9. Huawei P8 Lite Teardown: 9 단계, 이미지 1/2 Huawei P8 Lite Teardown: 9 단계, 이미지 2/2
    • Remove the battery. There is strong adhesive under the battery—work carefully to pry it free and be careful not to puncture the battery.
    • Try an iOpener or hairdryer to heat the adhesive behind the battery. This softens the adhesive, making it easier to release the battery.
  10. Huawei P8 Lite Teardown: 10 단계, 이미지 1/2 Huawei P8 Lite Teardown: 10 단계, 이미지 2/2
    • Remove the motor vibrator.
  11. Huawei P8 Lite Teardown: 11 단계, 이미지 1/1
    • Remove the sensor flex. It's covered under the digitizer flex and fastened by adhesive.
  12. Huawei P8 Lite Teardown: 12 단계, 이미지 1/1
    • Remove the earpiece speaker.
  13. Huawei P8 Lite Teardown: 13 단계, 이미지 1/3 Huawei P8 Lite Teardown: 13 단계, 이미지 2/3 Huawei P8 Lite Teardown: 13 단계, 이미지 3/3
    • Heat, cut the adhesive sticker and remove the screen carefully.
  14. Huawei P8 Lite Teardown: 14 단계, 이미지 1/1
    • You're done!
Sophia
회원 가입일: 03/25/14
43,810 평판
안내서 62개 작성하였습니다
댓글 10개
Ciao ma la pistrina nera sulla batteria da dove posso comprarla? Perché mi è arrivato un terminale con il flat tagliato della pistrina e dovrei sostiturila.. Oppure può farne ammeno e cambio solo la batteria?
vito - 답글
thank you, its inspirating
buchta - 답글
Hello, I completed this repair and now the back-light is not working. Any suggestions? Know where I could locate a diagram of this board? TIA
beck74 - 답글
THis mobile audio ic for main speaker need information. because audio is full off on my phone but buzzer is health and good please help me but handset and small speaker are working
mohandes - 답글
Sir sent me p8 lite LCD light track
umarshazad001 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 17
30일 전: 60
전체 시간: 107,461
