주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Huawei P9 수리는 저희 서비스 설명서를 사용하십시오.
  1. Huawei P9 Teardown, Huawei P9 Teardown: 1 단계, 이미지 1/3 Huawei P9 Teardown, Huawei P9 Teardown: 1 단계, 이미지 2/3 Huawei P9 Teardown, Huawei P9 Teardown: 1 단계, 이미지 3/3
    • Huawei made an iPhone a luxury unibody phone. Are the specs as pretty as the case?
    • 5.2" 1080 x 1920 (~423 ppi) IPS-NEO LCD
    • Huawei Kirin 955 Octa-core CPU (4x 2.5 GHz Cortex-A72 + 4x 1.8 GHz Cortex-A53) and Mali-T880 MP4 GPU
    • Dual 12 MP, f/2.2, 27 mm, Leica optics, dual-LED flash; 8 MP front-facing camera
    • 32 or 64 GB internal storage, expandable via MicroSD (up to 128 GB additional)
    • Rear-case-mounted fingerprint sensor
    • Android 6.0 Marshmallow
  2. Huawei P9 Teardown: 2 단계, 이미지 1/3 Huawei P9 Teardown: 2 단계, 이미지 2/3 Huawei P9 Teardown: 2 단계, 이미지 3/3
    • Huawei beat Apple to the smooth-rear-case-punch, offering a slim phone, without the infamous camera bump.
    • Antenna bands, chamfered edges, brushed aluminum and—Pentalobes? The P9 seems to have taken the iPhone design as law, down to the nasty proprietary five-lobed screws.
    • This marks the first time we've seen such a tiny pentalobe screw outside the Apple ecosystem; we can only hope this is an outlier, not a trend.
    • Seriously, there's no good reason to use pentalobe screws. They are shallow and have round lobes, making them excessively easy to strip. The only reason to use them is to prevent the average user from getting them out.
    Pent-a-lobe screws are fantastic.
    2 screws to get into the device, in my opinion, makes repairs much easier than the typical android way of using glue and glass.
    also, the fact that they are a 5 lobe screw means they have more points of contact, and less chance of rounding. If you find yourself rounding pent-a-lobe screws, you’re doing it wrong.
    squirt350 - 답글
    use torx plus
    Meow Purr -
  3. Huawei P9 Teardown: 3 단계, 이미지 1/3 Huawei P9 Teardown: 3 단계, 이미지 2/3 Huawei P9 Teardown: 3 단계, 이미지 3/3
    • Following our iPhone design hunch, we break out the iSclack, just in case there's a sneaky fingerprint sensor cable trap.
    • Turns out Huawei fixed that too! A long accordion-like cable allows the rear case to be almost entirely separated from the rest of the phone, making disconnection easy.
    • A little heat and some prying earns us a somewhat familiar-looking fingerprint sensor.
  4. Huawei P9 Teardown: 4 단계, 이미지 1/2 Huawei P9 Teardown: 4 단계, 이미지 2/2
    • Brackets and screws start flying as we dig right in, disconnecting the battery for starters.
    • First to fall: the 8 MP, ƒ/2.4, selfie cam, its connector secured by some simple tape.
    • The front-facing camera is cute (and packs a pixel-dense punch), but we're really after its big brother(s).
    • We're slightly bummed we didn't get to test out the fancy software features that compliment this hardware. The Perfect Selfie will have to wait.
  5. Huawei P9 Teardown: 5 단계, 이미지 1/3 Huawei P9 Teardown: 5 단계, 이미지 2/3 Huawei P9 Teardown: 5 단계, 이미지 3/3
    • The fancy dual-rear-facing camera is on a single ribbon cable, making it easy to pluck free.
    • This (purportedly impressive) dual camera unit is made up of two image sensors: An ordinary 12 MP RGB sensor, and a 12 MP monochrome sensor.
    • The additional monochrome sensor aims to add depth and contrast to color photos (while functioning as a nice black-and-white camera, too).
    • The dual-camera assembly is noticeably shorter than the bump-inducing iPhone 6s camera, but not by much.
  6. Huawei P9 Teardown: 6 단계, 이미지 1/2 Huawei P9 Teardown: 6 단계, 이미지 2/2
    • Who left their gum in here? Peeling up the motherboard reveals more thermal paste in a phone than we've seen in awhile.
    • Here are the front-side chips:
    • HiSilicon Kirin 955 (likely a HiSilicon Hi3650) octa-core processor layered underneath 3 GB of SK Hynix H9CKNNNDATMUQRN-UH LPDDR3 RAM
    • Samsung KLMBG2JENB-B041 32 GB eMMC NAND flash memory
    • Texas Instruments BQ25892 fast charging IC
    • HiSilicon Hi6402 audio codec
    • Maxim Integrated MAX98925 audio amplifier
    • Altek AL6610-72M1 AI camera processor (likely)
    where is the SOC?
    marjiehi - 답글
    May be packed with the DDR3 RAM
    Atom Zhang -
    it's a luxury unibody phone,why lpddr3?
    David Grey -
    where is the 55nm VIA CDMA modem?
    Roc - 답글
    does anyone know the part number for the NANO SIM/uSD holder?
    I’m guessing it’s the TE 2290741-1 or 2295782-1 , but it looks a bit different. (I’ve found another teardown where it looked exactly the same)
    https://www.androidheadlines.com/2016/04...
    Lóránd-Tamás Kertész - 답글
    Can I use Arctic Cooling MX-2 to replace pink gum?
    Geir Stensrud - 답글
  7. Huawei P9 Teardown: 7 단계, 이미지 1/1
    • And bringing up the rear:
    • Broadcom BCM4345 5G Wi-Fi and Bluetooth 4.0 controller
    • Broadcom BCM47531A1—likely similar to the BCM4752 GNSS controller
    • NXP Semiconductor 54802 (PN548) NFC controller
    • Skyworks SKY78117, SKY78114, and SKY78113 SkyOne front-end modules for WCDMA/LTE and FDD/TDD LTE
    • HiSilicon Hi6421 power management IC
    • HiSilicon Hi6422 power management IC
    • Skyworks SKY87020-13 power management IC
  8. Huawei P9 Teardown: 8 단계, 이미지 1/2 Huawei P9 Teardown: 8 단계, 이미지 2/2
  9. Huawei P9 Teardown: 9 단계, 이미지 1/2 Huawei P9 Teardown: 9 단계, 이미지 2/2
    • IC Identification, pt. 3:
    • NXP Semiconductor BGU8009 GPS/GLONASS/Galileo/BeiDou low-noise amplifier (LNA)
    • NXP Semiconductor BGU8M1 LTE LNA
    • NXP Semiconductor BGU8H1 LTE LNA
    • Murata 324 Ln RF switch (likely)
    • Texas Instruments LP8758-E0 4-ch. step-down DC-DC converter
    • Texas Instruments TPS65132 display power supply
    • Texas Instruments DRV2605 haptic driver
  10. Huawei P9 Teardown: 10 단계, 이미지 1/2 Huawei P9 Teardown: 10 단계, 이미지 2/2
    • IC Identification, pt. 4:
    • ON Semiconductor battery fuel gauge (likely)
    • Monolithic Power Systems MP3312GC LED driver
    • Texas Instruments flash controller (likely)
    • ON Semiconductor FUSB301A USB-C controller
    • ANGSemi Microelectronics AS3646B analog switch
    • Maxim Integrated MAX13042E 4-ch. bidirectional level translator
    • Renesas (formerly Intersil) ISL91110IIAZ adjustable buck-boost regulator
  11. Huawei P9 Teardown: 11 단계, 이미지 1/2 Huawei P9 Teardown: 11 단계, 이미지 2/2
    • IC Identification, pt. 5 (sensors):
    • STMicroelectronics VL53L0X time-of-flight sensor (likely)
    • STMicroelectronics LSM6DS3 3-axis accelerometer/gyroscope
    • AKM Semiconductor AK09911 3-axis compass
  12. Huawei P9 Teardown: 12 단계, 이미지 1/2 Huawei P9 Teardown: 12 단계, 이미지 2/2
    • Huawei is making it rain modular parts!
    • Despite rumors of a headphone jack free iPhone, the P9 features a standard 3.5 mm audio jack, compatible with your existing headphones.
    • It's also an independent, modular component that comes right out without desoldering!
    • The USB-C daughterboard also comes free with minimal hangers-on.
    • USB ports classically suffer a lot of wear—we plug our phones in at least once a day—so it's good to see a separate and easy to replace USB-C port.
    Where are the accelerometer and gyroscope?
    vessel - 답글
    in questo momento dello smontaggio vi siete dimenticati di smontare una lastrina di metallo con un contatto circolare dorato che copre/blocca il connettore principale della scheda USB che io non vedo. è una lastrina che ha la sua importanza
    Mario Rossignoli - 답글
  13. Huawei P9 Teardown: 13 단계, 이미지 1/2 Huawei P9 Teardown: 13 단계, 이미지 2/2
    • The itty bitty spring-contact-connected earpiece speaker pops right out of the display assembly.
    • Spring contacts are always a nice find, they make disassembly nearly foolproof.
    • The loudspeaker (complete with foam plug) takes a little encouragement from a plastic opening tool, but is shortly freed as well.
    • That bit of foam may be a method of ingress proofing for the speaker, keeping dust and pointy objects at bay. But it looks a bit like an afterthought, if you ask us.
  14. Huawei P9 Teardown: 14 단계, 이미지 1/3 Huawei P9 Teardown: 14 단계, 이미지 2/3 Huawei P9 Teardown: 14 단계, 이미지 3/3
    • Pulling at some familiar black tabs we are elated to find adhesive pull tabs under the P9's battery.
    • We can't praise these tabs enough. They are an easy-to-use and inexpensive way to secure the battery in a reversible manner.
    • And a good thing, too—with those two orange interconnect cables under the battery, prying through thick adhesive easily could have been dangerous for Mr. P9's health.
    • Huawei lists a couple specs for their battery: A "rated capacity" of 11.08 Wh and a "typical capacity" a bit higher at 11.46 Wh.
    • That puts the P9 battery ahead of the iPhone 6s Plus's 10.45 Wh and just under the Samsung Galaxy S7's 11.55 Wh battery.
  15. Huawei P9 Teardown: 15 단계, 이미지 1/2 Huawei P9 Teardown: 15 단계, 이미지 2/2
    • Huawei P9 repairability score: 7 out of 10 (10 is easiest to repair):
    • Modular components with spring contacts, thoughtful cabling, and minimal adhesive all make repair cheaper and easier.
    • The battery is straightforward to access. Removing it requires knowledge of the adhesive removal technique, but is not difficult.
    • The display assembly is a fused unit, and replacement requires near complete disassembly of the phone.
    • The P9 inexplicably uses Pentalobe security screws on the exterior, requiring a specialty screwdriver to open the phone.
Tobias Isakeit
회원 가입일: 03/31/14
117,781 평판
안내서 188개 작성하였습니다
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 회원
Business
1 회원
안내서 1,082개 작성하였습니다
댓글 43개
Very plain and normal,just a mark of qualified
David Grey -
Even the iphone 6s has a better repairabilty score.
[deleted] - 답글
Come on, this deserves a 8/10!
Random Username - 답글
Does the P9 use IOS?
davesax11 - 답글
maybe that the sun rises in the west is more realizable
David Grey -
Sure. And OS X simultaneously. Geez, what a...
Adam -
Like all Android Phones, it uses IOS as it’s glitch ;)
Florian Bohlken -
Leica lens? Are the photos better?
Sergio Castro - 답글
its lens are from sunny optical technology corporation which locate in ningbo,zhejiang province of China.
David Grey -
Fused display is never going away, it's just far better this way, you can stop giving red marks for it.
uhohumm - 답글
Huawei is showing to be highly advanced in phone design, this teardown proves it - they are by far ahead of Chinese competition and it's design simplicity compared to the S7 is impressive.
Question though - where are the antenna's? they are not showing in this teardown as far as I could find?
Ferdi - 답글
huawei always claims itself as an innovator,while acts as a copycat to use its advantage of advertisements and local public opinion over apple.it's not a good rival.it's just a theif who always copy others' designs of conceptual products.
David Grey -
Let me get this straight, who did Huawei copy from? It introduced dual-lense camera with a black-&-white one for better texture, and then Apple introduced its own dual-lense solution months later. Who is the copycat here? I use Apple products and love them. But false accusations just sound sour and mean...
Luke Duan -
Thank you very much for the guide !
eliiilevi - 답글
disagree with this result, from this tears down this is a really good phone and easy repair. how you got your conclusion of huawei is a copycat? this is a really bias. even the american government want to found hawei is a copycat, but so many years past , what they got?
yi collin - 답글
I suppose the government wants to show Huawei is a copycat because it's from chinses ? But I agree with the result somehow. Huawei introduced dual-lense camera earlier than Apple, but the texture of P9 doesn't prove itself. I think it just cooperate with Leica on some scenarios and get an attestation on the device only.
Storm -
great.cool.very good teardownning
arya z - 답글
Hi i 'd like to know if huawei p9 single sim bought in italy (EU) supports quick charge in the same way of Huawei p9 plus. Thanks
Fabrizio - 답글
so easy!great!
JAMES TANG - 답글
很棒,亲测拆机过程中电池是比较容易坏
aifutech - 답글
Versions: EVA-L09 (Single SIM); EVA-L19, EVA-L29 (Dual SIM).... Which version was this ??
An10na - 답글
It was the EVA-L09 model
Tobias Isakeit -
How can the glass infront of the camera in the back be replaced
ali77alhassani - 답글
I need some help! Huawei p9 after replacing display appears grey screen. I controled all and I don't know what can i should do. :'(
Rey - 답글
Hello i have a question,
I have a Huawei p9 and i need a morherboard (EVA-L19).
Where can i order, links pls or contacts.
My phone is Huawei p9 EVA-TL00 china version :/ and dont work some app in europe.
Pls help me thx frends.
Gamer95 - 답글
Bonjour, après une très rapide chute dans un peu d'eau et un démontage intégral pour sécher l'intérieur de mon téléphone, celui ci fonctionne de nouveau mis à part le wifi et le bluetooth. Grâce à votre site j'ai pu identifier le composant qui semble défaillant mais je ne sais pas ce que je peux faire de plus... Est il possible que j'ai mal connecté quelque chose ? Ou que le composant ait été endommagé par l'eau ?
Merci d'avance
Troyes - 답글
Hey there, My battery consumption is around 800mA/h =/ it is way too high. what may be the reason for this? I changed my LCD screen. However, it says that screen only takes 25% of consumption. it seems reasonable to me. Thanks.
chenbo luo - 답글
华为给力支持国产加油嗷嗷
buyuliang - 답글
I was change the lcd Huawei p9 but I have problem in display light plz tell me display light ic hardware solution
Waleed - 답글
Hello,
I need somme help, the fix cheap of the scanner fingerprint is broken do you know where I can but the replacement parts ?
Olivier - 답글
能不能自己换玻璃面板啊,换总成屏幕感觉太贵了
CPT.PRICE - 답글
where can i bay the pink thermal paste ??
medlamine Semassel - 답글
Bonjour s'il vous plaît aider moi j'ai tout fait impossible de démonter mon téléphone huawei p9 il ne sort pas de sa $!^& j'ai enlevé les deux vices mais le bloc écran refuse de sortir
Mounet Gaudo - 답글
Is it possible that we can replace only battery without touch pannel ?
rafay - 답글
i broke a cable to a tiny sensor (square chip) with a cable that has 3 contacts on it at the bottom right of the phone if you open the back. can someone please tell we what part this is so I can order a replacement?
a owen - 답글
buenas, mi celular fue sumergido en agua, tiene reparaciones o repuestos para la venta ?
Yuraima - 답글
Hallo,
Vielleicht hat ja jemand das Phänomen beim P9 ebenfalls feststellen können. In meinem Fall ist es ein Kundengerät, bei dem nach einem Displaytausch die Sprachverständigung bei Telefonaten nur schlecht möglich ist. Der Gesprächspartner kann meinen Kunden kaum verstehen. Die Sprachaufzeichnung funktioniert hingegen wunderbar. Das Huawei kann sich auch einwandfrei mit dem Mobilfunknetz des Kunden verbinden.
Ich habe vorsorglich die Öffnungen des Gerätes gereinigt von aussen und innen(Platine und Display waren demontiert).
Was könnte ich noch tun? Den roten Gummistopfen am USB-C-Board will ich nicht entfernen, da dieser ja das Eindringen von Feuchtigkeit verhindern soll. Oder hat schon mal jemand bei schlechter Verständigung diesen Stopfen entfernt bzw. mit einer Nadel vorsichtig ein Loch
dort hinein gemacht, um eine Verbesserung herbeizuführen? Das USB-C-Board wurde beim Displaytausch erneuert, weil sich bei der
Demontage der Coax-Anschluss am USB-C-Board gelöst hat(kalte Lötstelle). Das Coax-Kabel ist neu.
Bernd Nienhaus - 답글
Hello,
My Huawei P9 GPS chip has died (I think), what part of the phone do I need to replace to fix this?
Martijn van den Berk - 답글
Geir Stensrud - 답글
Weis irgendjemand wie die kleinen Abdeckungen heißen die über dem Akkustecker sind. die mit einer Schraube fixiert sind
Florian Haibl - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 22
30일 전: 104
전체 시간: 162,150
