주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Humax IRHD 5000C 수리는 저희 서비스 설명서를 사용하십시오.
  1. Humax IRHD 5000C Teardown, open up case: 1 단계, 이미지 1/2 Humax IRHD 5000C Teardown, open up case: 1 단계, 이미지 2/2
    • Unscrew the screws on the outside.
    • Slide the top cover a bit to the back, and lift it from the enclosure.
  2. Humax IRHD 5000C Teardown, remove power supply: 2 단계, 이미지 1/2 Humax IRHD 5000C Teardown, remove power supply: 2 단계, 이미지 2/2
    • Remove the various pieces holding in the power supply.
    • Remove power cable (already cut of in the photo).
    • Unscrew screws.
    • Disconnect mainboard cables.
    • Remove the power supply from the enclosure.
  3. Humax IRHD 5000C Teardown, remove front: 3 단계, 이미지 1/2 Humax IRHD 5000C Teardown, remove front: 3 단계, 이미지 2/2
    • Disconnect the cables connecting the mainboard to the front panel.
    • With a flathead screwdriver, unclip the 2 topside clips, and 3 clips on the bottom of the enclosure, and the front will detach.
  4. Humax IRHD 5000C Teardown, disassemble front: 4 단계, 이미지 1/3 Humax IRHD 5000C Teardown, disassemble front: 4 단계, 이미지 2/3 Humax IRHD 5000C Teardown, disassemble front: 4 단계, 이미지 3/3
    • Unclip the 4 clips from left to right, and remove the panel.
    • With the pliers, clamp the white connector and push it through.
  5. Humax IRHD 5000C Teardown, remove mainboard: 5 단계, 이미지 1/2 Humax IRHD 5000C Teardown, remove mainboard: 5 단계, 이미지 2/2
    • Unscrew the screws and remove the mainboard from the case.
knipwim
회원 가입일: 09/01/18
8,527 평판
안내서 30개 작성하였습니다
댓글 2개
What are those unsoldered pad connectors for? A hard drive?
Jessica Parnelli Fawkes - 답글
Don’t know, could be a SCSI drive, there are 68 pins. I included a detail picture in the last step.
knipwim -
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 7
전체 시간: 1,428
