주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Hyppe Max Air 5000 수리는 저희 서비스 설명서를 사용하십시오.
  1. Hyppe Max Air 5000 Teardown, Bumper Removal: 1 단계, 이미지 1/3 Hyppe Max Air 5000 Teardown, Bumper Removal: 1 단계, 이미지 2/3 Hyppe Max Air 5000 Teardown, Bumper Removal: 1 단계, 이미지 3/3
    • Remove rubber bumper
  2. Hyppe Max Air 5000 Teardown, Shell Removal: 2 단계, 이미지 1/1
    • The plastic shell is ultrasonically welded shut
    • This is due to the disposable nature of the device
    • I don't have images of the removal process but I used a razor to lightly go along the seam and then spit it apart with a spudger
  3. Hyppe Max Air 5000 Teardown, Mouthpiece Removal: 3 단계, 이미지 1/2 Hyppe Max Air 5000 Teardown, Mouthpiece Removal: 3 단계, 이미지 2/2
    • Lift upwards
  4. Hyppe Max Air 5000 Teardown, Battery Removal: 4 단계, 이미지 1/3 Hyppe Max Air 5000 Teardown, Battery Removal: 4 단계, 이미지 2/3 Hyppe Max Air 5000 Teardown, Battery Removal: 4 단계, 이미지 3/3
    • Lift up the battery
    • 3.7V 1.85Wh
  5. Hyppe Max Air 5000 Teardown, Charge Port Removal: 5 단계, 이미지 1/2 Hyppe Max Air 5000 Teardown, Charge Port Removal: 5 단계, 이미지 2/2
    • Use the point part of the spudger to get under the port and pry it up
  6. Hyppe Max Air 5000 Teardown, PCB screw: 6 단계, 이미지 1/2 Hyppe Max Air 5000 Teardown, PCB screw: 6 단계, 이미지 2/2
    • Remove the PH00 screw
  7. Hyppe Max Air 5000 Teardown, Airflow sensor: 7 단계, 이미지 1/3 Hyppe Max Air 5000 Teardown, Airflow sensor: 7 단계, 이미지 2/3 Hyppe Max Air 5000 Teardown, Airflow sensor: 7 단계, 이미지 3/3
    • Use the ponty end of the spudger to lift up the airflow sensor
  8. Hyppe Max Air 5000 Teardown, Electronics Removal: 8 단계, 이미지 1/2 Hyppe Max Air 5000 Teardown, Electronics Removal: 8 단계, 이미지 2/2
    • Use flat end of spudger to pry out chamber
    • Everything should now be come out of the plastic housing
  9. Hyppe Max Air 5000 Teardown, PCB Closeup: 9 단계, 이미지 1/2 Hyppe Max Air 5000 Teardown, PCB Closeup: 9 단계, 이미지 2/2
    • Some close up images of the PCB
  10. Hyppe Max Air 5000 Teardown, Heater Removal: 10 단계, 이미지 1/3 Hyppe Max Air 5000 Teardown, Heater Removal: 10 단계, 이미지 2/3 Hyppe Max Air 5000 Teardown, Heater Removal: 10 단계, 이미지 3/3
    • Pull on the heater and it should just pop out
    • It's interesting to see that the heater geometry is just a mesh
  11. Hyppe Max Air 5000 Teardown, Chamber Lid Removal: 11 단계, 이미지 1/2 Hyppe Max Air 5000 Teardown, Chamber Lid Removal: 11 단계, 이미지 2/2
    • Use the spudger to pop off the rubber lid of the chamber
  12. Hyppe Max Air 5000 Teardown, Wicking Material: 12 단계, 이미지 1/2 Hyppe Max Air 5000 Teardown, Wicking Material: 12 단계, 이미지 2/2
    • Pull out the foam-like material
  13. Hyppe Max Air 5000 Teardown, Metal Core: 13 단계, 이미지 1/3 Hyppe Max Air 5000 Teardown, Metal Core: 13 단계, 이미지 2/3 Hyppe Max Air 5000 Teardown, Metal Core: 13 단계, 이미지 3/3
    • Use spudger to push out core
    • The heating element sits inside the sleeve. There is some wicking material on the inside to bring the nicotine liquid close to the heating mesh.
ShellingRook27
회원 가입일: 08/21/19
1,876 평판
안내서 7개 작성하였습니다
Repair For You Repair For You 회원
Business
1 회원
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 17
30일 전: 74
전체 시간: 2,004
