소개
Chip view not available due to low quality photos. I'll get on that asap.
필요한 것
We'll start with a preview of the phone. Front, back and side view are shown here.
After the battery is out, we're presented with a plastic cover with all the phone's information (Model No., Serial No etc)
Notice the 4 Philips screw-heads in each of the four corners. Those need to go off.
After unscrewing, you might notice that the cover doesn't easily go off. Four clips are holding the back cover onto the front cover.
Use a Spudger and unclip the sides of the cover. It shouldn't put up much resistance
By this stage, the board simply comes out of the front body, exposing the keyboard and its associated membrane.
On the board we encounter the ringer(upper left), the headphone/handsfree input(under the ringer) and the LCD (which is sadly sticked on the board, as is the keypad membrane)
On the case we encounter the microphone (lowest part of the phone case), the loudspeaker (the highest part of the phone case)
